Old 03-29-2010, 03:08 PM   #1 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
a local rolling resistance ad
I compare my car to a prius for tires..(it is in the specs) .and found this ad on my local craigslist. It is beyond ecomod chats now, this is great. I may purchase, as my car is awd.
For Sale:
Set of four Bridgestone Potenza G019 Grid size P185 65R15. Used for about 9 months.
Bridgestone web site for this tire: Bridgestone Potenza G019 Grid
We bought the G019s to replace the worn out OEM tires on our Prius. The OEM tires were terrible in wet conditions and we needed something that would provide better traction. While these Bridgestone G019s provided GREAT traction, we were not aware of the decrease in gas mileage they would cause on a Prius. We went from an average of about 55 mpg to about 44 mpg. I have since learned that the Prius is sensitive to the rolling resistance of it's tires. The G019s were designed for excellent traction but not for low rolling resistance. I did some calculations and determined that we can actually save money by replacing these tires with low rolling resistance tires so we are selling the gently used G019s. We use winter tires mounted on their own rims during the winter months so these G019s were used only for about 9 months of non-winter driving.
prius
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 66 05-22-2012 06:52 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Measure tire rolling resistance with a bounce test Ernie Rogers EcoModding Central 8 01-08-2010 07:36 PM
