Old 07-18-2008, 10:43 AM   #1 (permalink)
Looking for a 12v A/C or low watt 110V unit
Hey all,
I am looking for a 12v or low watt 110v Air Conditioning unit for car passenger compartment use. If 110v it has to be below 150 watts.
Any idea's?
Old 07-18-2008, 10:50 AM   #2 (permalink)
Audi A5 - '010 A5 2.0T Premium Plus
90 day: 30.17 mpg (US)
Prius - '012 Prius Four
90 day: 52.86 mpg (US)
check out these units from swampy, have one on my boat and it works fine. it will not cool down the car interior but it will cool you down if you direct the cold air flow at yourself, AKA from the passenger seat.
!MightyKool Personal Coolers by Swampy
Old 07-18-2008, 10:59 AM   #3 (permalink)
Thanks for the suggestion but I am looking for an a/c unit not a swamp cooler. The swamp cooler would raise the ambient humidity in the car too high causing musty smells or worse, mold and mildew.
However, this idea might be feasable in arid areas like AZ, NM and NV.
Old 07-18-2008, 02:20 PM   #4 (permalink)
What do you guys think about something like this? According to an online BTU calculator the Ford Escape needs about 3000 BTU for comfort. This unit is 4400 BTU so I figure its a nice safety margin. Do you guys think something like this would be better than running the ICE driven A/C?
DC Airco type 4400 is designed and used for cooling small cabs, and sleeper cabs of (EU) trucks.
DC 4400 is a small lightweight dc air conditioner introduced in 1998, and modified in 2003.
DC 4400 12 volt
DC 4400 24 volt
Cooling capacity
1300 Watt – 4400 BTU
1400 Watt – 4760 BTU
Power consumption
360 Watt 30A
360 Watt 15A
Size mm
Size inches
700 W x 920 D x 265 H
27,5W x 36,3 D x 10,5 H
700 W x 920D x 265 H
Weight
30kg / 66 lbs
30 kg / 66 lbs
Max. outdoor ambient
40 ºC / 104 ºF
40 ºC / 104 ºF
Low voltage settings
(Unit will shut down if there is a low voltage)
12 VDC = 10,5 volt
24 VDC = 21,5 volt
Restart settings
(If there was a low voltage the unit will restart at)
12 VDC = 12,6 volt
24 VDC = 25,2 volt
High pressure switch
24 bar
24 bar
Low pressure switch
2 bar
2 bar
Safety switches
Max. temperature compressor and motor
dc 4400 - dc powered air conditioners
