Old 09-29-2009, 10:51 PM   #11 (permalink)
Just spend $40 for a 12v air compressor that looks like it has a good gauge... The gauge is the important part.
Old 09-30-2009, 12:02 AM   #12 (permalink)
Wait for a deal at Harbor Freight. You'll be able to get a reasonably good air compressor for $50 and a digital pressure gauge with fine adjustment valve for $15. It works much better than those cheap tire pumps.
I even added a few feet of 1/4" copper tubing (bent into a coil) between the pump and tank on mine so I can inflate the tires with cool air.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 09-30-2009, 12:19 AM   #13 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
For inflating tires; $35 yellow 12 volt compressor at pepboys.
End of discussion.
6 speed ALH TDI
Old 09-30-2009, 01:24 PM   #14 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
End of discussion.
Yup. A full size compressor is nice to have, but you don't want to carry it around in your trunk.
Old 03-04-2011, 05:17 PM   #15 (permalink)
Liberty Lover
johnlvs2run's Avatar
honda - '99 civic ex
chevy - '89 celebrity
. - '00 .
Originally Posted by Clev View Post
I have the cheapy cigarette lighter version. They have the cheaper one (fills a tire in as little as 8 minutes!) and the more expensive version (fills a tire in as little as 3 minutes!) If you have any kind of regular leak, I'd say go with the more expensive one. The cheaper one that fills a tire in 8 minutes also takes 8 minutes to take a tire from 38 psi to 51 psi.
What is the difference between a cheapy one and one that's expensive?
There are some 300 psi 12v compressors on Ebay for less than $20.
Old 03-04-2011, 06:16 PM   #16 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
My cheapy one was this one:
Walmart.com: Slime - Portable 12 Volt Tire Inflator with Built-in Gauge and Light: Automotive
After a few minutes of running, the tip of the cigarette lighter plug was so hot that it caused first degree burns. Eventually something inside the unit burned up, so I replaced it with another cheapy from somewhere else.
Old 03-04-2011, 06:25 PM   #17 (permalink)
Liberty Lover
. - '00 .
How about one like this?
Should 300psi be enough to pump tires to 50psi fairly easily?
Also how much does one of these run down the battery?
Old 03-04-2011, 06:51 PM   #18 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Should be fine, but for the same price, I'd pick one up from Target. That way, you have some recourse if it burns up in a week.
No worries about the battery. Even if you ran it for an hour, it wouldn't make a significant dent.
The Following User Says Thank You to Clev For This Useful Post:
johnlvs2run (03-04-2011)
Old 03-04-2011, 07:23 PM   #19 (permalink)
6 speed Diesel FTW!
Diesel
the cheap ones run for about 10 mins before over heating. Sometimes they recover, sometimes they do not.
I highly recommend the Yellow one at Pepboys. Often times on sale for $25 Sometimes on sale for $20 You can always return to pepboys as well. It will run continuously for 6 truck tires (Load range E 245 75 R16 i think) from 30 psi to 90 psi without missing a beat. However, make sure that you outlet is up to snuff, these pumps draw a SOILD 15 amps at 12 volts.
6 speed ALH TDI
The Following User Says Thank You to dremd For This Useful Post:
johnlvs2run (03-10-2011)
Old 03-10-2011, 12:01 AM   #20 (permalink)
Liberty Lover
. - '00 .
I ordered this 12v air compressor tonight.
And this AC to 12V DC power adapter converter.
Midwest Renewable Energy Association Fair - June 19-21 2009 Custer, WI bennelson Events & Meet-ups 5 06-22-2009 11:47 AM
My EVs at MREA Energy Fair 2009 bennelson Fossil Fuel Free 3 06-20-2009 09:27 AM
Let's be fair on the high-mileage EVs Ernie Rogers General Efficiency Discussion 150 05-27-2009 02:26 AM
Anyone going to the illinois renewable energy fair? dann_04 Events & Meet-ups 6 08-06-2008 03:52 PM
A/C Compressor Died RH77 Saving@Home 13 07-09-2008 01:05 AM
