Old 07-18-2008, 12:07 AM   #1 (permalink)
Looking at buying a civic vx. FE question
Gas Mileage of 1992 Honda Civic
They show 2 VXs and I can't tell what the diff is.
Here the only diff is SIL (Shift indicator light)
Side-by-Side Comparison
I don't think that alone would gain you 5 mpg would it?
Old 07-18-2008, 12:33 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
The way they do the tests with SILs is weird. I would consider them equal, if I were you. Only thing to look out for is that the cali version will get worse mileage than the non-cali version.
Welcome to ecomodder!
Old 07-23-2008, 07:50 PM   #3 (permalink)
An easy way to tell the difference between the CA & Fed (49 state) VX's is to look at the oxygen sensor located on the top of the exhaust manifold.
The fed -with lean burn activated- will use a 5 wire sensor. The CA version will have a 4 wire sensor and no lean burn. One caveat is that the '92 CA VX had a 5 wire sensor but the ecu for the car didn't utilize it.
So, for the '92 VX's only, the way to tell is to look at the last three characters of the ecu. If it has an "L00" or "L01" it'll be a CA vx w/o lean burn. If it has an "A00" or "A01" then it's the fed version.
Clear as mud?
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 03:52 PM
Why the Civic VX is a superior highway FE machine MetroMPG General Efficiency Discussion 9 10-10-2010 06:26 AM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 07:37 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
newb intro and question about civic hb vx reformed Introductions 9 01-30-2008 12:28 AM
