Old 05-10-2009, 11:23 PM   #1 (permalink)
Shadow - '93 Shadow ES
90 day: 24.34 mpg (US)
Moped - '06 50
90 day: 137.2 mpg (US)
Looking into a kill switch
After experimenting will engine-off coasting for the first time tonight, I'm considering installing a kill switch and start switch. I read several threads on these and from what I've read, you can kill the ignition, injectors, or fuel pump. Which of these is best? I don't want to leave unburned gas in the cylinders, or hurt the fuel pump. My vehicle is a 93 Dodge Shadow and my last tank averaged 24mpg city. A kill switch seems like the next necessary step to boosting my mpg. Any advice? Thanks.
Old 05-11-2009, 01:14 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
bkruger -
Welcome to EM! I checked your car. Because it's a manual, you can probably do the kill switch first and use bump-starts at first. You can always use the key or install the start switch second.
My opinion is that different drivetrains have different "best" solutions. I know that for my Saturn, intercepting the fuel injector fuse will work, but I haven't got around to it (no excuse).
CarloSW2
American Solar Energy Society
Old 05-11-2009, 04:39 PM   #3 (permalink)
Moped - '06 50
It seems there is no diagram for my fuse box anywhere. Is there an easy way to tell which fuse is for the fuel injectors?
Old 05-11-2009, 05:13 PM   #4 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
If you have the owners manual for your car there should be a diagram of the fuse panel in it and a description of what each fuse controls.
Old 05-11-2009, 05:21 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
bkruger -
Here is one clue :
WikiAnswers - Where is the fuel pump relay on a 1993 Dodge Shadow
it is front of the master break cylnder on the drivers side the liitle black box that has the fuses has 4 plugins on the front of it sitting parell with the fuse box and the second plug is the relay to the best of my knoweldge, i had called oreilly autoparts and they looked it up on the computer , i do know that it was one of the four plugs for positive , i havent wnet bac an messed with mine as its been so cold and wet.
It's not the fuel injector fuse, but maybe it's one of the other fuses.
More good stuff here :
WikiAnswers - Dodge Shadow Questions including "Where is the heater blower motor in a 1988 4 cyl Dodge Shadow"
CarloSW2
Old 05-11-2009, 11:02 PM   #6 (permalink)
Moped - '06 50
I've looked all through the manual and a Chilton manual. The main fuse box is only for lighting, radio, etc. Under the hood, there are 5 or so black boxes, with wires that runn all over the engine bay. I'm assuming this is ignition, injection, etc. I'l post pictures tomorrow unless someone with a similar model can tell me which one it is or a good way to put in a switch. I brought a 12v 20a switch. Is that sufficient?
Kill switch how-to bbjsw10 DIY / How-to 161 09-22-2011 05:19 AM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 36 06-27-2011 05:24 PM
Kill switch signal cutting options Daox EcoModding Central 19 01-28-2011 03:25 PM
Fuel injector kill switch for '05 Scion xB The Fridge DIY / How-to 21 09-24-2010 04:37 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 11:31 PM
