Old 11-20-2008, 02:09 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Looking for a low battery voltage switch
I'm looking for a switch that monitors battery voltage. At a set voltage the switch would trigger a LED or relay. Anyone have any ideas on where I could get something like that? I know autospeed has one but I'm really not looking to order something from Australia.
Old 11-20-2008, 02:56 PM   #2 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I can confirm that getting something from Autospeed can take a while. My order was shipped via airmail 11 days ago. Must have been shipped in a Beaver.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-20-2008, 07:19 PM   #3 (permalink)
A simple comparator circuit is all you need.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 11-20-2008, 09:30 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Daox -
Here's one :
Universal Voltage Switch
Ref: High Performance Electronic Projects for Cars - Silicon Chip Publications.
This is a universal module which can be adapted to suit a range of different applications. It will trip a relay when a preset voltage is reached. It can be configured to trip with a rising or falling voltage, so it is suitable for a wide variety of voltage outputting devices eg., throttle position sensor, air flow sensor, EGO sensor. It also features adjustable hysteresis (the difference between trigger on/off voltage), making it extremely versatile. You could use it to trigger an extra fuel pump under high boost, anti-lag wastegate shutoff, and much more. Kit supplied with PCB, and all electronic components.
Jaycar electronics is "joined at the hip" to Autospeed.
CarloSW2
American Solar Energy Society
Old 11-21-2008, 08:01 AM   #5 (permalink)
CM400E - '81 CM400E
Yeah, I know autospeed carries two versions of the voltage switch. I like the one I posted more because its all solid state construction and thus I don't have to worry about the relay ever dying. Also, I just would like to find a place in the US that has this sort of thing. Someone has to have something like it on this side of the pond.
NiHaoMike, I know I need a voltage comparator and that it would be a relatively simple circuit. However, I don't know enough about electronics to build one myself. The problem being that the reference voltage will vary. Unfortunately, I don't even know enough to look at a circuit and know if this problem has been solved. Lastly, I'm willing to pay a bit (not a ton) just to have it premade so as to save me the time and hassle. If you have any suggestions, or a diagram that would be great.
Old 11-21-2008, 10:02 AM   #6 (permalink)
Use a zener diode as a reference.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
HCH 1 battery running low MasterAlex Hypermiling / EcoDriver's Ed 4 08-04-2008 02:41 PM
How Low Can You(r Battery) Go? Fuzzy EcoModding Central 2 01-07-2008 10:15 PM
