Louvered wheel wells on race cars
I'm talking about the row of louvers on the top of the front fenders, right ahead of the side view mirrors.
What's their purpose? Are they for something boring and non-ecomodder applicable like brake cooling, or are they evacuating the wheel well to eliminate aerodynamic drag at the front wheel arch? Or something else? http://i337.photobucket.com/albums/n...charlie/bp.jpg http://i337.photobucket.com/albums/n...doran_mc12.jpg |
I'm no genius when it comes to aerodynamics but to me it looks like their trying to pull air out the top of the wheel well (trying to keep it from going under?). although the top one seems like a weird place to jet it (right at the mirrors?).
That would probably be done for brake cooling.
Tango Charlie -
Jackpot! I googled "racing wheel louvers" and got this : AUTO-RACING - NASCAR Racing Schedule - F1 - Formula 1 - Drag Racing - Motorsports - Indy Car - SPEEDtv.com Quote:
CarloSW2 |
Awesome link, cfg83! :thumbup:
That definitely answers my questions. Now I'm wondering how to implement it on my Vibe... :p |
Tango Charlie -
CarloSW2 |
Great thread.
Well don't most cars have plastic fender liners/wheel wells? Seems easy enough to cut slots in those! (Then again, where does the air go after that?) I've often thought that the climate control system has great potential to assist with aero. Perhaps some kind of ducting could be rigged up so that the fan pulls air from the wheel wells? |
louvers
Remember,these are race cars! Their windshields are inside the wake area of the fender-top extractors.In inclement weather,there will be quite a rooster-tail of rain water exploding out the top of those fenders.If it doesn't destroy your vision,it may not be the same for those following in traffic.Also,you may completely destroy the airflow in that area.GTP cars can have drag coefficients like Cd 0.7!!!!!!!!! They're way cool at the track,and they need a lot of brake cooling coming off a straightaway into the first curve.Not the sort of thing we'll be doing on daily commutes.
i believe something similar, useing an inverse scoop like setup was first used on a 70's muscle car... can't come up with the name though.
one thing that puzzles me is that this seems to sugest rheres high pressure in the wheelwells, while other sources sugest there's a low pressure... i could accept eihter case, but i'm running a bellypan i'm somewhat relying on the "low pressure theory" for radiator air extraction. or is this the reason these sports cars use this setup as well? |
Thanks, aerohead. I hadn't thought of the rain aspect. That would be a sight to see!
Racecars are so beguiling. They look so sleek and sexy, yet so many of their features don't translate to FE on our daily drivers. But What if we (somehow) ran a duct from the inner wheel well back to the rear of the car into a low pressure area... The size of duct to make a difference would probably make it not feasible. |
