Old 06-13-2008, 08:18 AM   #1 (permalink)
6'8" Comfor and Safty
Low-Drag Trucks: Aerodynamic Improvements & Flow Control System Boost Fuel Efficiency
http://gtresearchnews.gatech.edu/new.../truckfuel.htm
The big rig drivers should appreciate this one, but here is my question. Could the wings be modified for SUB and Van owners. I imagine xB owners could benifit as well.
Old 06-13-2008, 09:08 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I would say yes they could. They are essentially a mini-boat tail like Andrew has on his Civic.
Old 06-13-2008, 10:39 PM   #3 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I think we could benefit from anything that offsets the toasterness, really. Failing that, I could just avoid the interstate system entirely.
Old 06-14-2008, 12:53 PM   #4 (permalink)
flow control
certainly,there is no physical boundary that would prevent such a thing to benefit vans and SUVs.This kind of research is in at least it's second decade of work. So far,the energy balance comes out on the side of the atmosphere.The energy required to pump the air,exceeds the energy saved in drag reduction,for a net loss in efficiency. I personally belong to the Clarence"Kelly"Johnson' school of KISS ( keep it simple stupid! ) and like others,believe the class-8 truck and semi-trailer requires a complete re-think.Fifteen years ago there were bus designs with Cd 0.20. Renault had a 18-wheeler with Cd 0.318. And no moving parts!!!!!! I think these would serve as appropriate starting points,as they work.A heroin addict may argue that his problem lay in the design of the syringe,however,I believe the problem occurs at a deeper level. I'm sure Georgia Tech is having a great time making bonfires out of my tax dollars.I do believe the money could be better spent elsewhere.Great article,now I'm going to go and shoot myself.
Old 06-15-2008, 09:54 PM   #5 (permalink)
Hermit
Aubergine - '94 Ranger 4x4
90 day: 19.14 mpg (US)
The under wing was interesting. I have wondered recently if there would be any value in streamlining my Ranger rear axle (in combo with belly pan/side skirt), if only to add downforce and counteract potential lift issues of an aeroback.
It seems like such an easy change. After decades, how hard could it be to put some rounded extensions on a box?
Old 06-15-2008, 11:38 PM   #6 (permalink)
Danger Ranger - '01 Ranger Edge 4x4
90 day: 13.25 mpg (US)
Moms car - '05 Freestyle Limited
90 day: 21.92 mpg (US)
Send a message via AIM to meemooer
Kindda funny how the article is from January of 2005!!
what have they been waiting on? why doesn't someone[company] just build something cheap, slap it on a truck and see if it works at all. 0.5mpg better is a big money saver on a big rig
Randy
CdA list Daox Aerodynamics 106 03-30-2012 06:02 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
