Low RPM load limits? Lugging?
What load limits do you use when you are at low rpms? I find that below 1500 rpm, operating at too high a load makes the engine sound and feel rough, which I assume is nearing the lugging point.
idle-1300: 40% load(sometimes a little more) 1300-1400: 50% load 1500-infinity and beyond: No limits |
Below 1500 is probably always too low for flooring it for any purpose at all. But above that, in a naturally aspirated and relatively low-power engine that is also in good working order, there is not much chance of damage. ECUs will adjust timing and AFR as needed to avoid pre-detonation. Nonetheless, 1500 is my absolute bottom for relatively high load (75%, which is a long way from WOT). But generally I am at 1700 or higher as I accelerate. Been doing this for years all the time and have 248,000 miles on the original engine now. ;)
Great video here: https://www.youtube.com/watch?v=soJe...ature=youtu.be |
In my Insight, the engine feels fine wide open down to maybe 1200rpm. At those low revs, even barely touching the pedal is enough to give it 100% load, because it needs so little air.
Edit: Recently passed 220k and it still runs like a brand new engine. |
Drive by wire throttle won't let you do anything that's bad for the engine, IMO.
For my 8L engine build I would like to cruse along at 70mph turning 1,400rpm. If the engine doesn't like that I will have to change rear end gears.
Number of cylinders and/or displacement count, imo.
My 3 cylinder Geo isn't much good under 2000rpm at heavy load, whereas my wife's V6 happily chuggs down the the highway at 1500rpm. My Miata (read: DOHC/high-revving) is a turd below about 2500 rpm. |
That guy does such great tutorials. My head feels funny, did I just learned something?!!
Have I missed something here? All the BSFC graphs I see seem to show that the engine is less efficient at low RPM & higher load.
