Old 07-29-2011, 01:33 PM   #1 (permalink)
low speed EV and a truck with a gereator what can i do?
i have a 1980 stepvan with an integrated generator that gets terrible gas mileage (unleaded v8 auto)
i have a candi koko low speed electric car
is there anyway i could build a hybrid with these two vehicles?
Old 07-29-2011, 02:43 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'm sure you could, but you probably wouldn't want to drive it. I haven't looked up the specs on your EV, but I highly doubt it has enough power to push around a stepvan at anything other than really slow speeds. Plus, to integrate the two would be a pretty huge amount of work.
Old 07-29-2011, 03:19 PM   #3 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Accord EX
HvyDrnkr - '93 Seville
Go either one or the other.
How about taking a small gen set and integrating it into the electric car as a range extender? Or make your own out of a 50-100cc engine and an alternator/generator to run at the optimal speed as needed to keep the batteries topped off.
Or you could do what I did and get the plans from Mother Earth News and modify them to fit your application.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
