Old 02-06-2011, 08:57 AM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Lower Cd, but larger wake
How is it that cars such as the '92 - '95 Civics have a slightly higher Cd ( .32 ) in 2door sedan form over the .31 of the hatchback ?
Even though the airflow separates on the back of the sedan due to the steep angle of the window, I would think that the size of the cars wake would make up for this and lower the Cd.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 02-06-2011, 09:26 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...no pictures in your post.
Old 02-06-2011, 11:26 PM   #3 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Because the hatchback more closely approximates the "Ideal Aero Template". The larger back surface area (So counterintuitive that 90% of the people in this forum who think they know better will argue) does not matter, it is how close we come to the template that matters, rear surface/wake area be damned.
Old 02-06-2011, 11:34 PM   #4 (permalink)
AeroModder's Avatar
Darwin - '96 Aspire 4 door
Team Ford
90 day: 44.82 mpg (US)
It's the virtual boattail effect.
In Reason we Trust
Old 02-06-2011, 11:37 PM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Er... hah?
The rear surface/wake area is THE DEAL MAKER.
BTW, how are the roof spoilers coming along?
Old 02-07-2011, 06:46 AM   #6 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Spelling
Look at your Avatar Cd.
It may be a larger wake area, but it reattaches smoothly.
The reverse eddies are what create the backwards suction we call drag.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 02-07-2011, 12:48 PM   #7 (permalink)
Cd
Ultimate Fail
Cd's Avatar
And more eddies equal more drag and a higher Cd right ?
The sedan ( actually coupe ) would have less of these eddies due to a smaller wake, as well as having the air re-attach just behind the trunk / boot.
Perhaps it is all just a misprint ?
I used to collect much of the same literature as Aerohead.
I had a sales brochure from Saturn that had the Cd figures for their cars and remember being puzzled at how that the Saturn station wagons had the same Cd as the SC-2 .
( it was either the SC-1 or the SC-2 . I can't remember after all these years. )
Old 02-07-2011, 02:23 PM   #8 (permalink)
AeroModder's Avatar
Team Ford
I think you need to start looking at CdA figures as well. The Cd can be the same for large and small cars, but when the frontal area is factored in, the drag numbers change.
In Reason we Trust
Old 02-07-2011, 03:20 PM   #9 (permalink)
Cd
Ultimate Fail
Cd's Avatar
It's the exact same car. The only difference is one is a coupe and the other a hatchback.
Frontal area stays the same. Same with the example of the Saturn coupe verus station wagon.
on early 90s Saturns, the front end was the same on both cars, as well as the frontal area.
Old 02-07-2011, 05:15 PM   #10 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
The way I'm seing it is this,
The coupe/sedan rear shape creates more eddies creating a negative pressure area on the rear window and trunk.
With the wagon, the airflow seperates more cleanly. This leaves a neutral pressure zone without the reverse holding currrent.
As a Saturn nut, the sc1/sc2 are the same body, the engine is the difference. Single vs dual cams. Same goes for the sw (wagon) and the sl (sedan, sl was the manual everything stripped model, 40 mpg hwy in a 1995).
Sorry to drift OT.
Support Bennelson !
