Old 12-18-2011, 11:08 PM   #131 (permalink)
OurInsight - '06 Insight
Had the same rust problem when I tried that on an Echo. A cheap solution would be to sand them, prime them with a red lead spray can, and paint to the color you like.
Old 12-19-2011, 02:13 PM   #132 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
I liked the silver color of the bare pans when I installed mine, so I hit them with some clear coat from a spray can. It's held up pretty decent. It was cold out when I did it, and I didn't prep them very good. Going into the second winter now, and they're starting to reveal my shortcutting ways.
They're so darn cheap, I'll just make a new set next spring.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 01-14-2012, 01:39 AM   #133 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Finally had an engine block heater installed on Friday !
Some of the mechanics at the dealership were impressed by the lower grille blocks...They said it gave the Echo a subtle and unique look.
Old 01-14-2012, 06:26 PM   #134 (permalink)
50mph sur la 50
echo-francis's Avatar
echo-troll - '05 echo
90 day: 58.74 mpg (US)
you will really see a difference in the shorter trips =)
Old 04-29-2012, 08:38 PM   #135 (permalink)
You could possibly pop plastic/aluminum pans over the steel pans or just go with a clear coat. In my situation, it would be cheaper to buy stainless or aluminum pans.
I really like your grille block. If you're using Bowden cabling with a bike brake, you should look into a Tektro lever with a brake lock/release and just have the thing sprung open, shut close (so you don't overheat if the cabling breaks). You can easily use elastic springs or metal springs to accomplish that.
I have an Echo in the family that is possibly going to be inherited by me, but it's an auto. I'm really interested in polishing it up (it being a smoker's car, yet has no smoke smell) and trading it in for a manual version (because honestly, most dealerships will have no trouble selling an automatic versus the manual). Thanks for providing info on your mods to your sedan!
Old 04-30-2012, 05:25 PM   #136 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
my auto has been doing great
34-36mpg in the city
Past Present Future?
Old 05-02-2012, 01:20 AM   #137 (permalink)
Really fun reading your Echo adventures
I also have an Echo with an AMSOil BMK 13 remote oil kit. Normal Echo is ~3.3 quarts of oil & with this kit I'm at 6.3 quarts. I was just thinking that the extra oil capcity might be a good way to keep engine temps down? I really don't know for sure but I can say I don't ever remember hearing my fan go on?
Anyway just a thought..
Old 05-02-2012, 09:01 AM   #138 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Might be a good way to keep engine temps down. But, you also want your engine to warm up quickly, and that'll hurt it in that respect. I'd say design the lube system to lube the engine and the cooling system to cool it properly.
Old 05-02-2012, 11:31 PM   #139 (permalink)
Hmmm? Well for reference it takes 7min in the winter & ~3 in the summer to get to operating temp. Are you saying it should happen even faster?
Another idea might be those coolant additives that racers use to keep their temps in check....something like Hyper Lube Super Coolant or Redline Water Wetter Super Coolant???
Old 05-06-2012, 12:04 AM   #140 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by California98Civic View Post
Looks really good. Makes your car unique in a subtle way. I like. Do most of the lower grill too. Duct air to the radiator through the remaining opening. That would look cool too.
No trying to hijack, but I appreciate what you've done here. I'm thinking of doing nearly the same thing with my RAM...
aero mod, grille block, toyota echo
