Old 01-05-2011, 09:08 PM   #41 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi Frank,
My gas water heater sits in the basement. I am thankful for whatever heat it "loses" there.
Yes, but some heat does go up the chimney, too?
Another trick I have seen in pre-warming the supply to the water heater with the draining water on the shower trap, with a heat exchanger.
Old 01-06-2011, 01:17 AM   #42 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Originally Posted by slowmover View Post
Can an instant heater be used inline with a tank heater? Will the instant stop heating once the tanked hot water gets to there?
It really depends on the on demand hot water heater, Quite Side makes one that will do exactly what you are asking as it has an temp sensor for the incoming water along with the outgoing water and a variable size flame so it only heats as much as is needed, other on demand water heaters pulse the flame so you get bursts of hot and cold water.
So there is no flat out rule for on demand water heaters, you have to study and choose and you tend to pay for what you get.
