Old 10-21-2011, 11:47 PM   #1 (permalink)
lowering trucks?
I have a 08 gmc sierra 1500 extended cab sitting on 265/70/17 tires, anyone know if lowering it would help out at all with fuel economy.
Old 10-21-2011, 11:57 PM   #2 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
It most likely would. It would probably be easier, though, to add an air dam and belly pan.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 10-22-2011, 09:19 AM   #3 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Protege5
90 day: 32.52 mpg (US)
yes, I had a 99 ranger XLT that I lowered 2 inches in the front and I saw about a 1-2 mpg increase on the hwy. of course, it did nothing for city driving except to make it much better handling.
by lowering it, your presenting a smaller frontal area. but I dont know how much of an effect it will have on a full sized truck.
~Mike
Old 10-22-2011, 01:13 PM   #4 (permalink)
lowering
Lowering gets you two birds with one stone:
*the small reduction in projected frontal area as already mentioned as some of the tires frontal area is reduced.
*then,the apparent fineness-ratio of the truck (length/height) is increased,always a benefit to production vehicles.
Old 10-22-2011, 11:22 PM   #5 (permalink)
I think lowering adversely affects payload ability.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 10-22-2011, 11:52 PM   #6 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Mustang GT
90 day: 24.7 mpg (US)
Id go lower if I was you. Then possibly look into grill block off.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 10-23-2011, 08:59 AM   #7 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Build a full belly pan first, while it's up higher. Easy to crawl under and attach your panels. Then lower it if you want. Make the panel easily removable (maybe stainless screws instead of rivets for example) to make undercarriage work reasonable to do.
I think you'll get more gain from the belly pan than from lowering - just a guess. But after you lower it building the belly pan is much more of a PITA.
Find the lowest part of what's underneath - probably the rear diff - and build the belly pan at that level. So the pan won't need to go up and down to clear stuff. Just cut it away where it needs to clear the suspension arms.
Grill block off - definitely a good idea. And faster/easier to do than lowering or belly pan, I would think. I strongly recommend a ScanGauge or any digital engine temp gauge so you will know the coolant temp. A needle gauge doesn't really tell you much. The engineers designed it with enough CYA so you can probably tow a big trailer across the desert with a/c running - but when you start modding it, their CYA design isn't there any more.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 10-23-2011, 10:07 AM   #8 (permalink)
See the link in my signature below. A simple chin spoiler is good for couple of MPG hwy. My black truck in the photo sits higher than the tan S-10 in the foreground, something the previous owner did.
Chin Spoiler:
Roof Wing
Old 10-23-2011, 10:17 PM   #9 (permalink)
I'm just wondering if lowering would affect hauling or handling on a truck this size. I definately am going to do the grill block. Does it need to be completely flush with the grill trim to be most effective or can it be recessed like the grill is now? As for the belly pan I need to crawl under and have a look to see what kind of fabrication I can do and how wide are they supposed to go; wide and as long as the vehicle is? Sorry for all the questions, new to the site and excited to squeeze some more mpgs from a full sized truck.
Old 10-24-2011, 12:13 AM   #10 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Wink
My belly pan thread fer my Toyota T-100 truck. Goal was not to put in any holes in the vehicle and use only existing stock holes/fasteners.
Under belly pan... - Toyota Nation Forum : Toyota Car and Truck Forums
