Old 02-16-2011, 04:03 PM   #1 (permalink)
Lowest /highest engine on neutral iGPH you've seen on each of your vehicles?
What's the lowest instantaneous GPH you've seen on any of your vehicles while your engine has been on and in neutral? Please no 0.0 responses; I think it would be interesting to see how much idle GPH can vary between and within our rides. Of course, the more info you can include about when you saw the numbers, the better, but even if you just give highs, lows, and your vehicle, that'll do. I'll start.
On my '95 Tercel, the highest I've seen it is around .78 or so right after starting the car on sub-freezing days where both IAT and engine coolant temps were showing 5F. The lowest I've seen so far is around .21 or so after driving around town during some of our slightly warmer days here with my radiator block installed. I bought the car in the late fall, so I'm not sure how low it can get. As spring arrives, I hope to see it drop below .2.
So short version:
Car: 1995 Toyota Tercel, AT.
High: .78
Low: .21
As you can see, that's quite a spread. 10mph at .78gph is 12.8mpg, while 10mph at .21 is 47.6 mpg. It really drives home how much of a role engine and air temps play in efficiency.
The Following User Says Thank You to bluejoey For This Useful Post:
SentraSE-R (02-17-2011)
Old 02-16-2011, 04:52 PM   #2 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
I think the lowest i've seen is .20GPH.
Old 02-16-2011, 05:36 PM   #3 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
lowest i've seen on my Jeep (3.7L V6) is 0.34, highest was around 0.8 (but it wasn't fully warmed up at that point)
Old 02-16-2011, 06:38 PM   #4 (permalink)
darcane's Avatar
Silverado - '03 Silverado W/T
Pickups
90 day: 18.7 mpg (US)
Ninja 650R - '06 Ninja 650R
90 day: 52.02 mpg (US)
2003 Silverado. 4.8L V8
Low: .44
High: ~2.75
It fluctuates a lot when I first start it up, but when it's cold, it uses a lot of fuel, even just idling. But it comes down pretty quick, it's under 1.0 within 10 seconds, and then gradually approachs the low as it warms up.
AC bumps it from .44 to .50.
Mike
2003 Silverado:
Aero Mods
Old 02-16-2011, 06:56 PM   #5 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I only have a SG on my VW.
It reads 0.10 when warmed up, cold it can go as high as 0.22.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 02-17-2011, 12:02 AM   #6 (permalink)
Wink 7200lbs of hypermiling heaven
On my '05 Ford Excursion 6.8L V-10 my Ultra-Guage reads 2.85 at 15 degrees F and the lowest I've seen it is .83 Obviously not the ideal commuter car but it does get used some depending on weather (bad) and my work schedule vs her schedule. We try to share the Honda CR-V (1.6 cold and .31 warmed up) for our winter commutes and save the big Ex for towing the race trailer and camper.
Old 02-17-2011, 12:15 AM   #7 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Lowest .08
Highest.21
I make no claims to the accuracy of my scanguage.
6 speed ALH TDI
Old 02-17-2011, 12:30 AM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
2006 Scion xB, 1.5 liter engine
0.67 gph at cold start (40 degrees F)
0.11 gph at idle when fully warmed up
0.14-0.15 gph is more typical for warm idle. I see those numbers 4 times out of 5, with the 0.11 gph seen 1/5 times
My 2002 Nissan Sentra SE-R Spec V with 2.5 liter engine
0.22 gph at warm idle
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 02-17-2011, 05:59 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
More info here:
How's your idle?
Piwoslaw's Peugeot 307sw modding thread
Old 02-17-2011, 08:28 AM   #10 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
1.5 upon starting from cold (open loop) quickly settles to less than 1.0
.15 when fully warmed.
