Old 04-09-2011, 05:56 AM   #31 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
http://www-nrd.nhtsa.dot.gov/pdf/esv/esv21/09-0300.pdf
Here is some test data on Rolling resistance. I understand that best low rolling resistance tires in that test are:
goodyear integrity and bridgestone potenze RE92 owl?
www.tuneko.com
Less drag = Less fuel
Old 04-09-2011, 06:54 AM   #32 (permalink)
Tire Geek
CapriRacer's Avatar
I find it interesting that the rank order changed slightly depending on which test was run.
I also find it interesting that the Goodyear Integrity and Cooper Discoverer ST-C were tested in 3 different sizes - and that the RRF values were different enough that one of the 3 was in a different grouping.
Old 04-09-2011, 09:12 AM   #33 (permalink)
Vekke's Avatar
Diesel
I have always tought that tire companies do almost all the R&D work on popular sizes. Then they will just scale it down to other sizes and widths and say that they are the same. Maybe that test proves my estimations true?
www.tuneko.com
Old 04-10-2011, 07:53 AM   #34 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Vekke View Post
I have always thought that tire companies do almost all the R&D work on popular sizes. Then they will just scale it down to other sizes and widths and say that they are the same. Maybe that test proves my estimations true?
While I can confirm that tire manufacturers develop tires in a couple of sizes, then scale them up and down as appropriate, I think what the test says is that there is something else going on and you can't compare the rolling resistance of tires of different sizes.
I'm surprised no one has posted this in this thread:
http://www.energy.ca.gov/transportat...%20Testing.pdf
It's a study done for the California Energy Commission. Not only does it test various tires for rolling resistance, it also studies the effect tire size has on rolling resistance. This confirms that different sizes of otherwise identical tires have different values - enough that you can't reliably compare tires of different sizes.
I ran a regression analysis on the data and developed an equation so the differences in tire size could be compared, but the R-squared value wasn't all that great: 66%
The Following User Says Thank You to CapriRacer For This Useful Post:
Vekke (04-11-2011)
Old 04-11-2011, 09:38 AM   #35 (permalink)
Vekke's Avatar
Diesel
Yes I also meant that popular sizes. Usually this means tires that are normally used as factory size tires on cars. There 3-5 popular sizes on different size cars. Other sizes are then scaled like you confirmed. This gived me a nice idea and lets see how things start to develop.
That report was superb. If you have more similar "open" reports on your sleeve please post .
www.tuneko.com
Old 04-11-2011, 12:45 PM   #36 (permalink)
Tire Geek
CapriRacer's Avatar
Yes I also meant that popular sizes. Usually this means tires that are normally used as factory size tires on cars. There 3-5 popular sizes on different size cars. Other sizes are then scaled like you confirmed...............
I know that in some places in Europe, only tires approved by the vehicle manufacturer are allowed to be applied - even as replacements.
That is definitely not true in the US. There are whole lines of tires - 30 to 40 different sizes, that are designed off a couple of prototypes - and that was what I was referring to.
- AND -
It is pretty universal that any OE tire is unique to itself. The vehicle manufacturer decides what the performance specs are supposed to be, and the tire manufacturer complies. If the tire manufacturer refuses to go along, te vehicle manufacturer will find some tire manufacturer who will.
Old 04-12-2011, 12:23 AM   #37 (permalink)
Musician w/ Light Wallet
SeaBiscuit - '98 Civic DX Hatch
90 day: 39.99 mpg (US)
I believe I've been able to identify at least one of those variables which change in a non-scalar way when tires are scaled up or down for size. For example, the legendary Bridgestone B381 185/70-14 tires have a 5.0" tread width, while the 185/65-14 version of the same tire has a 5.4" tread width. If my math is correct, that's an 8% increase in tread width, which would increase the size of the contact patch and also increase rolling resistance.
While looking at other tires, it seems the tread width of the same tire between different sizes goes up or down almost arbitrarily depending on the brand.
Tirerack is pretty good about giving detailed specs about tires.
JMac
Old 04-12-2011, 11:21 PM   #38 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
contact patch size does not change
the contact patch size does not change
if tire pressure remains constant
contact patch SHAPE changes with differing size / profile of tire , contact patch area / size remains constant
Old 04-13-2011, 06:12 AM   #39 (permalink)
Tire Geek
CapriRacer's Avatar
contact patch SHAPE changes with differing size / profile of tire , contact patch area / size remains constant [/COLOR]
Sorry, but that is an old wive's tale:
Fact or Fiction? Tire contact patch and air pressure.
If you want to assume that for the purposes of analysis, go ahead. Just be sure you don't draw any conclusions where that is a vital piece.
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
List of Low Rolling Resistance Tires Daox EcoModding Central 56 12-17-2010 08:10 AM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
Busting the non believers trikkonceptz Success Stories 30 09-28-2008 05:51 PM
