Old 01-03-2008, 11:32 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
LRR (low rolling resistance) tires - Green Seal report & list
For those considering replacing their tires with a LRR versions, this report is a good place to start for general info. It's getting long in the tooth (1993), but the basics still apply.
  • 1.5 to 4.5% of total gasoline use could be saved if all replacement tires in use had low rolling resistance
  • About 237 million replacement tires are sold in the U.S. each year – none has rolling resistance labeling
  • This report presents previously unpublished data on leading tires with low rolling resistance
Report (PDF): Green Seal's Choose Green Report: Low Rolling Resistance Tires
Old 01-05-2008, 12:27 AM   #2 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Excellent Report
This is a great report -- I used it to purchase my latest set of treads. I attribute a decent percentage increase to my over-inflated LRR's.
For more up-to-date info, Consumer Reports has rolling resistance data in their tire reviews. The problem is that it requires an online subscription to the site or the magazine. You may be able to check your local library and locate a hard-copy for reference -- but those are the only references that I've been able to find actual testing on this subject.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 01-05-2008, 08:25 AM   #3 (permalink)
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Prius
90 day: 67.34 mpg (US)
I saw the Consumer Reports report in late 2006. It rated rolling resistance the same way that it rates everything else, with the red dot / black dot system. There were no actual LRR numbers. At the top of the list in 2006 was the Michelin Energy MXV and just under that was the Michelin Harmony. I bought the Kumho A/S 795's for the Prius which ranked just below the Michelins, but were 1/2 to 1/4 of the price. The sidewall max is 35 PPSI but I have been running them at 50-55 PSI. 40k miles so far and easily another 40k in them.
Hopefully the 2007 report had actual LRR values in it. If so, I would go to the library to see it.
Old 01-05-2008, 08:40 AM   #4 (permalink)
With California's July '08 implementation of LRR labeling & standards, I'd expect it's going to get easier for the public to get info & make judgements than it has been.
My car's tires are more likely to dry rot off the rims before I ever wear them out, so eventually I'll have to shop for replacements too :P
Old 01-05-2008, 03:05 PM   #5 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
FYI that report is from 2003
The most comprehensive List I could find was (still old from 2005)
http://onlinepubs.trb.org/onlinepubs...tance_Data.pdf
http://forum.ecomodder.com/showthread.php?t=466
6 speed ALH TDI
Old 06-04-2008, 06:06 PM   #6 (permalink)
Whitey - '05 corolla LE
90 day: 31.33 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
not to grave dig, but I'm going to shop for some Low rolling resistance tires and was wondering what the best choice is as of right now...
Maybe there's a newer chart out now?
Old 09-13-2008, 08:56 AM   #7 (permalink)
is there a more updated source?
Old 10-12-2008, 12:36 AM   #8 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Metro LSi
90 day: 48.88 mpg (US)
Even if there is an up to date study, those tires mentioned are still awesome to look into. Just looked at the top of the line Bridgestone B381's and they are going for about 90 bucks a piece. Steep price, but they are the best on the original study.
.02
Old 10-16-2008, 02:37 PM   #9 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
Here's some new info in an easy to read source ---> Low-rolling resistance tires - Wikipedia, the free encyclopedia
Old 10-16-2008, 03:33 PM   #10 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 61.71 mpg (US)
I just bought 2 new Michelin Energy Saver Tuesday. The bad news is they were pumped at 23 lower than the minimal placard (33) so I pumped them up to 46 this morning
After a little search I found that :
Sommerreifen 195/65 R 15 V (2008) - Tabelle
Sorry, it's in German... Thanks to babelfish :
Code:
trocken             = dry
nass                = wet
geräusch            = noise
kraftstoffverbrauch = fuel consumption
verschleiss         = wear
I don't know how they did their tests. The french forum in which I found the link was saying that my tires have a very good note except for breaking on wet grounds, so they are "recommendable" and not "particularly recommendable".
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
List of Low Rolling Resistance Tires Daox EcoModding Central 56 12-17-2010 08:10 AM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
Busting the non believers trikkonceptz Success Stories 30 09-28-2008 05:51 PM
