Old 03-04-2012, 05:36 AM   #1 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
MAF Reading
Hi All,
I'm modifying OBDuino to utilise a protocol from Nissan (Consult II).
In doing so, I've found that the g/s MAF reading is not available - I get a V reading instead.
Any thoughts if I can use the V reading someway (i.e. scale the reading to equal a g/s rate)?
Or if not, I can get injector pulse rate - how would that fit in a calculation? Injector duty would show how long each is open for, knowing the flow rate of the injectors - wouldn't it be possible to know how much fuel is going in? Would that be less accurate than the MAF method?
I don't have MAP accessible as a parameter either - the MAF sensor is there - but doesn't appear to be via the data reading.
Old 03-06-2012, 04:18 AM   #2 (permalink)
toc
Any takers?
Old 04-13-2012, 09:46 PM   #3 (permalink)
Saturn Freak
Freddy - '95 Saturn SL2
Team Saturn
90 day: 34.25 mpg (US)
The OBDI version of MPGuino uses the injector pulse and VSS signal to calculate mileage (vss/pulse*k where k is a constant determined by the number of cylinders, injector flow rate, etc.) I would think using the injector pulse would be more accurate than MAF/MAP since it's a more direct measure of fuel usage.
