Old 09-07-2008, 05:48 PM   #1 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.12 mpg (US)
magnets use for permanent mods ?
Hi,
Who is using magnets in their permanent mods ?
I'm looking for a simple way to attach my permanent rear skirts. I do not want to drill and I want to be able to remove them fastly (in case of cops' curiosity or technical control). I saw metrompg's solution but I can't find a easy way to implement it from what I can find in local stores.
I know that some small wifi and GPS antennas can stay on car's roof at high speeds (personally tested at 90mph) only attached with a magnet.
Because of my 16 months old son, I have to install magnets on drawers and doors. A search found supermagnete site. There is several thin magnets (<0.2 inch), each can support several lbs and these aren't too expensive. A dozen by rear wheel skirt should be enough...
A first difference between these permanent skirts and my cardboard skirts is the weight. The permanent one should be several lbs each. Another difference is the surface attachment, the tape had much more surface than the magnets will have, so the force/surface ratio will have to be much bigger.
What are your experiences ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 09-07-2008, 06:15 PM   #2 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
cfg first turned me to magnets.
I found these and was thinking about using them but wanted to first use tape tests.
5 Rare Earth Neodymium MAGNETS .75 x.75 x 1/8 Block NEW: NSN0512 Phoenix Trading Company
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-07-2008, 06:52 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
groar -
At post #8 I use magnets for my Airtabs :
Where to buy vortex generator fins?
I used magnets because I wanted the option of squeeky clean removal if I didn't like them aesthetically. Happily, no one has swiped them (knock on virtual wood).
Starting at post #50, blackjackel used magnets to install the framework for a rear wheel skirt :
Help with my aero mods: 1.8L 05 Auto Toyota Corolla
The above hasn't been finished, but the frame has held on at freeway speeds. The key was to have a magnet on both ends, a magnet on the car and on the frame.
I also have an idea to incorporate magnets for a Kamm-Back, but I haven't got around to that project.
CarloSW2
American Solar Energy Society
Old 09-08-2008, 01:12 AM   #4 (permalink)
Danger Ranger - '01 Ranger Edge 4x4
90 day: 13.59 mpg (US)
Send a message via AIM to meemooer
hmm... has me thinking about using some now. Maybe for me they would help with a bellypan and rear wheel skirts
Randy
Old 09-08-2008, 01:11 PM   #5 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Magnets are great -- if you have steel all around your wheel openings. On my xA though, about 1/2 of the surrounding material is plastic...
Also, magnets are much thicker than tape, so they will stick out into the air stream to a greater extent.
Old 09-08-2008, 04:52 PM   #6 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Lee valley sells rare earth magnets quite reasonably. Lee Valley Tools - Woodworking Tools, Gardening Tools, Hardware
They have a starter kit with an assortment or you can order them one at a time in most sizes.
Depending on the way you attach the skirts they will probably work very well. I think if the wind can't get under your mod to pry it off you are o.k.
I use them for attaching one of those $1.49 foil blankets from a camping store when I park in the sun. It's almost as good as parking in the shade and the magnets are almost invisible on the silver plastic. The long magnets work best because you can get a grip on them. The flat ones are hard to pull off.
Another way for quick detach is dzus fasteners which were invented for aircraft panel quick release. The are spring loaded, flush and can be installed with rivets or screws. Also used in auto racing, etc.
Self-Ejecting Fasteners
could we estimate the gains expected from mods modmonster EcoModding Central 9 01-15-2010 09:32 PM
GM mods the Sierra hybrid pickup: aerodynamic tweaks + LRR MetroMPG EcoModding Central 4 12-27-2009 12:11 PM
Ford Ranger Mods So Far... landscaper52 Aerodynamics 18 09-16-2008 06:14 PM
Aero mods for our coupes?? swoody Aerodynamics 14 09-05-2008 03:07 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
