Old 01-11-2013, 09:20 PM   #1 (permalink)
Civic - '95 Honda Civic EX
Question Major loss in MPG
I have a '95 Civic EX with the 1.6 in it. I haven't done really any modifications to it but I have been getting about 38 MPG with it until recently when one tank dropped to about 30 and then went up back up the next tank. It went back and forth a few times and now has stayed low for the last several times. I was getting the same fuel from the same station this whole time. Any ideas on what could make the fuel mileage drop so much like that? Thanks!
Old 01-11-2013, 09:46 PM   #2 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
sometimes the pump doesn't stop at the same point every time, so if it stops too soon your calculations show you got good MPG, then next time you may fill up more and you get worse MPG..also the winter is killer on fuel economy...
are you idling more than before? and tires low on air? are you still driving the same type of trips as before or are they different?
Old 01-12-2013, 01:23 AM   #3 (permalink)
No, not idling anymore than before, my tire pressure is the same, and my trips have been the same, between home and work, 27 miles one way. I don't drive hard and haven't changed my driving style.
Old 01-12-2013, 01:43 AM   #4 (permalink)
darcane's Avatar
Do you use a mpguino or anything to monitor real time fuel consumption? This would make it easier to see if it is caused by your behavior.
Cold weather has a big impact on fuel economy, especially if you have to let it warm up to get the windows clear enough to drive.
Some mechanical problems can cause increased fuel consumption. A failing O2 sensor is high on the list of the usual suspects.
Any other symptoms you have noticed?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 01-12-2013, 02:11 AM   #5 (permalink)
One other thing that I have noticed is the car sort of surging during acceleration. Sort of like I am pumping the throttle even though I'm not. I have wondered if it could be a sensor of some kind.
Old 01-12-2013, 11:37 AM   #6 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Cold weather saps 5-8 MPG outta my 04EX for certain. 2 Months ago going cross country, I got 42 MPG at 65°F, the next day, cold front passed over me (ya think?) and it was lower 20's°F with a 20-30MPH headwind kicker, 28MPG. I hate North Dakota.
Old 01-12-2013, 12:30 PM   #7 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
Surging doesn't sound normal. Could it be a vacuum or fuel delivery issue?
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
Old 01-12-2013, 01:23 PM   #8 (permalink)
GRU
GRU's Avatar
the problem it could be anything...if it's surging something is wrong...it could be the distributor or anything else. take it to a mechanic unless you can diagnose some engine problems
Old 01-14-2013, 09:42 AM   #9 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
When was the last time the vehicle was serviced? Surging during acceleration is definitely not normal.
Project Avalon: E bike build
Old 01-14-2013, 05:58 PM   #10 (permalink)
Rusty crusty trusty - '94 Honda Civic Cx
90 day: 36.13 mpg (US)
Vx - '92 Honda Civic Vx
90 day: 49.97 mpg (US)
Hook up a vacuum gauge. Surging sounds bad
