Old 07-07-2008, 12:16 AM   #1 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
make the car heavier to gain mileage?!
as the title states. It does happen.
As some may remember the crazy wobbling inline transverse of yester year (now unlikely to be so sloppy), when motor mounts were tightend, body structures failed.
As we all do not live in paradise for sheet metal, I do not know of a failure that isn't possible, to this day.
I recently have been working with a 21 year old subaru. knobby tread, 15 inch wheels, AWD 5 speed dual range, and a claimed weight of 2300 pounds. After doubling the rocker panels, adding frame work, wheel wells, rear quarters, all welded...I gained fuel mileage. The frealy little car sounds like a monster truck with the thumping studless snow tread on the hot tar at 35mpg.
the engine became a rock in its spot. It occured to me...short stroke little engines lose for every movement against thier fire stroke. Adding roughly 21 pounds of steel permanently in strategic locations of structure added fuel mileage, regardless of my -20s F winters to 90 degree july.
A thought to ponder no doubt....
Of course boxers and inlines do many opposites, and fuel injection may like the shaking, I am working with a carb original 1781 cc boxer. Smooth tread is back in the
high 40s mpg on the highway.
Just thought I would throw the idea out there if anyone has reached a dead end with thier little engine being a hog for no apparent reason. This is an odd reason, but worth a mention.
Old 07-07-2008, 02:31 AM   #2 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
really if you hade very flat terrane the weight would mean nothing.. my terrane slightly hilly weight means alot.... weight over all decreases effiecency.. more weight is harder to get going .. but allows for more coasting ability.. however most people dont coast nearly what they can in there cars.
Old 07-07-2008, 03:29 AM   #3 (permalink)
Originally Posted by bgd73 View Post
Adding roughly 21 pounds of steel permanently in strategic locations of structure added fuel mileage...
Even if your theory's correct, though, it's not the 21 pounds that increased the mileage, it's the added stiffness. If you could have somehow added the same stiffness with zero weight increase, you'd do even better.
Old 07-07-2008, 09:27 AM   #4 (permalink)
Harebrained Idea Skeptic
The White Car - '84 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 535i
Last 3: 23.86 mpg (US)
Old 07-07-2008, 10:11 AM   #5 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Ive been wondering that about my Celebrity. I took at least 150 lbs out of the trunk, and still got 32 mpg going downstate and back, just like before. I notice that the back end sits up a little higher now since the springs are not as compressed, and maybe that added wind profile offsets the weight decrease. Some cheap lowering clips on the rear springs might tell the tale of whats really going on.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-07-2008, 07:33 PM   #6 (permalink)
Changing weight makes comparatively little difference on highway FE (relative to city). If you're running stop and go traffic, or running up inclines, then extra weight will make a significant difference.
Also, in your case, that 150 lbs. is likely only 5% or so of the total weight. That may have improved things but you'd need to average a number of tanks to see that subtle a difference.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 01:07 AM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 10:31 AM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
