10-15-2009, 09:55 PM
Maker of twin-turbo kit for Corvette claiming massive (167%) city MPG increase.
Via GreenHybrid ...
I don't quite know what to make of this. The claims are so outrageous I was compelled to contact the company for more information.
First, the story:
What if you could have a 2008 Corvette that could get 40 mpg around town and 32 on the highway? How about you could not only get those mileage figures and your Corvette would also have over 650 horsepower? GenesVettes.com has done just that with their new Twin Turbo kit for the 2008 Corvette.
The car's EPA rating is 16 mpg city / 20 highway.
(FYI, 40 mpg is 167% higher than 16 mpg - that's the figure I'm referring to in the thread title.)
The kit consists of twin turbos plumbed into the exhaust under the rear of the car in place of the OEM mufflers, with plumbing to get the PSI back forward to intercoolers up front and then into the engine.
The company says the turbos are CARB registered and 50 state legal.
To try to build some eco credibility, they've given the kit a silly name, in my opinion: " Green Interactive Hybrid System"
I wrote to the email address on their site ( http://www.neohydrotechnology.com) and asked what exactly made it a hybrid in terms of the general understanding of what a hybrid is in automotive terms:
The response:
Hybrid does not necessarily mean a mix of gas and electric. We believe that more accurately it means a mix of two technologies. In out case patented rear mounted turbocharging linked to a conventional gas engine.
Okey dokey! Techically true. Also confuses the issue. Perhaps that's one of their goals, so I'll chalk it up to simple overzealous marketingspeak. (I didn't ask what exactly makes it "interactive".)
I also asked about the fuel economy figures: 1) if they were US gallons (because the company is in Canada), and (2) how they were determined:
The licensor has done extensive real world driving around town and highway testing. How much fuel between fills divided by miles driven. We are using U.S. gallons.
So, unfortunately here we have another example of an organization with dyno time (!!) which does not deem using said dyno appropriate for producing valid fuel economy comparisons. Shades of the Truck Trend K&N filter/intake debacle?
I was also told:
We drove a Silverado from Bellingham, WA to San Francisco towing a Corvette on a trailer through the mountains and averaged 19 mpg for the trip.
10-15-2009, 10:02 PM
ooo ooo ooo ah ah ah
Doug Palmear must be involved somehow...
10-15-2009, 10:08 PM
Sounds too good to be true.
Did they tell you the price? There are similar rear-mounted turbo systems available, but they don't claims the mpg figures...
10-15-2009, 10:16 PM
Rear turbos aren't new.
They turbo it, chip it, and do the standard performance remapping.
That's it.
There is no hybrid even though they named it "Green Interactive Hybrid System". No batteries, no motors, no hydraulics, no compressed air, no flywheel... nothing hybrid.
My understanding of "CARB #s" is that having one doesn't automatically make it street legal. It just means the CARB has identified it.
They will be the first tuners in the world to double fe by merely throwing a turbo on.
Well why not. It seems there are no bad repercussions from lying your *** off these days.
10-15-2009, 10:19 PM
I was editing the post as you guys were reading it. They explained the "hybrid" moniker because... a turbo + a conventional engine = technological "hybridization".
Technically true, but...
10-15-2009, 10:22 PM
They're actually saying on their site:
one of the few turbo systems that have a CARB EO #, making them legal in all 50 states.
10-15-2009, 10:26 PM
I saw that.
Exempted parts are add-on or modified parts that have undergone an ARB engineering evaluation. If the part or modification is shown to not increase vehicle emissions, it is granted an exemption to emission control system anti-tampering laws. This exemption is called an Executive Order (EO) and allows the modification to be installed on specific emission controlled vehicles. Every Executive Order part or modification has an assigned number that can be verified by Smog Check stations, BAR Referee stations, or by the ARB.
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
EO: D-593 View PDF
EO Date: 8/3/2005
Manufacturer Name: Squires Turbo Systems, Inc.
Device: Turbocharger Kit
Device Type: Turbocharger System / Turbocharger Modification
Part_Number: Model_Specification: Modification_Allowed: Remarks:
1999 through 2005 model year General Motors trucks equipped with V8 engines, 2004 and 2005 model year Pontiac GTO vehicles equipped with a V8 engine, and 1998 through 2002 model year Camaro/Firebird vehicles equipped with a V8 engine The Turbocharger Kit includes the following main parts: Garrett turbocharger, model number T04E 60-1 (Trim P, 0.81 A/R turbine, 0.6 A/R compressor), piping from the throttle body to the turbocharger, piping after the muffler to the turbocharger, open element air filter, wastegate, and PCV switch valve. Control module is reprogrammed using a hand held programmer with no user adjustments. Installation requires the air filter to be located near the rear wheel fender. Passenger cars will have an open element filter and trucks may have either an open element filter or a closed element snorkel kit. Boost is limited to 6 pounds per square inch.
EO: D-593-1 View PDF
EO Date: 1/29/2007
Device: Corvette TurboCharger Kit
1997-2005 model year Chevrolet Corvettes
http://www.arb.ca.gov/msprog/aftermk...rmktdevice.php
There are, oh, a zillion turbo kits listed so that in and of itself isn't special or unique.
Oh, I remember what it was about CARB numbers: having one is NOT an endorsement for power or fe increases. It merely doesn't break any laws.
10-15-2009, 10:35 PM
Moderate your Moderation.
CARB ID doesn't mean it's legal, CARB EO does. (Exemption Order)
I'm not doubting that there was SOME FE increase, but I think 40MPG city is just a ridiculous thought.
Then again, check out that site name: NeoHYDROblahblah.com
I bet they're running some HHO in those turbos.
According to STS, makers of one of the rear-mount turbo kits, they don't even need intercoolers, and having them gives no performance increase, rather just increasing boost restriction and pressure drop. They did a piece on PowerBlock a few years ago on the STS kits. They were actually quite impressive.
10-15-2009, 10:44 PM
#9 (permalink)
Oh, I rememeber what it was about CARB numbers: having one is NOT an endorsement for power or fe increases. It merely doesn't break any laws.
Same thing with "EPA registration". You have to register with them as well if you're going to market an aftermarket fuel economy product in the US. As with CARB, registration does not = endorsement, but some dubious companies market their registration in the hopes people do not know that. (Which is probably the case.)
10-15-2009, 10:50 PM
#10 (permalink)
Yes, I do find the rear-turbo concept appealing and wouldn't mind having one.
I wouldn't expect any fe increase at all though.
If, as CARB says, boost is limited to 6 psi, then according to this boost/HP estimator:
Your new HP computed from your old HP of 420 at Blower Boost of 6 psi is 591.48 HP. Vette
Your new HP computed from your old HP of 315 at Blower Boost of 6 psi is 443.61 HP. Silverado
Wallace Racing - Estimate HP From Adding Boost Calculator
their claimed increases:
2008 Chevrolet Corvette C6: 40mpg town (stock 16mpg, a 150% increase) | 775 HP (stock 420hp, a 84.5% increase) | 691 lbs torque (stock 424 lbs, a 62.9% increase)
2009 Chevrolet Silverado 1500 | 32mpg town (stock 14mpg, a 128.5% increase) | 500 HP (stock 315hp, a 58.7% increase) | 450 lbs torque (stock 338 lbs, a 33% increase)
GenesVettes.com - The Radical Solution
are rather generous.
Well, that would match the generous fe claims too.
