Submit Tools LinkBack (2) Thread Tools
Old 02-06-2010, 05:08 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Cycling more to drive les
White 'rolla - '05 Corolla LE
90 day: 50.27 mpg (US)
Send a message via AIM to Chalupa102
Making a better belly pan
I finally got around to getting some new coroplast today and am making a better belly pan in the front than what i had. Eventually i'm gonna do one for the rear as well.
I remember reading somewhere that someone got worse f/e because it had a parachute affect, so i believe they added a reverse scoop. Will i need one as well to release air coming in so it won't get trapped?
I do have my grills blocked right now, at least for the winter and the top one will remain blocked throughout the summer.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Corolla aeromods thread:
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/making-better-belly-pan-12196.html
Posted By For Type Date
EcoModder.com Latest Blog Posts This thread Refback 02-06-2010 09:29 PM
Making a better belly pan - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 02-06-2010 05:32 PM
Honda Fit Belly Pan Project Fit Aerodynamics 9 08-03-2010 01:19 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 34 07-31-2010 02:02 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 17 03-06-2010 09:41 AM
Belly pan soon White118 Aerodynamics 15 02-04-2010 10:51 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
