Old 09-28-2010, 10:06 AM   #1 (permalink)
Making Diesel Engines Burn Gasoline
Has anyone seen this article about the work at Argonne National Laboratory?
Making Diesel Engines Burn Gasoline | Autopia | Wired.com
The Following User Says Thank You to rbrowning For This Useful Post:
Frank Lee (09-28-2010)
Old 09-28-2010, 12:04 PM   #2 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
They need to be careful of fuel lubricity in diesel injection systems. Gasoline is incredibly dry. Maybe they could add some biodiesel.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 09-28-2010, 03:43 PM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
UFO: read the article.
Old 09-28-2010, 03:58 PM   #4 (permalink)
UFO
UFO's Avatar
I did that. My comment is based on this quote...
"Our approach is to use a fuel injector — in this case a diesel fuel injector — but use fuel that is difficult to auto-ignite. In this case, gasoline."
Diesel injectors require high pressure to inject directly into the cylinder, and these parts are immersed in the fuel. If it doesn't lubricate, the metal wears prematurely.
Old 09-28-2010, 04:16 PM   #5 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Oh I see. It must not be a "traditional" or mechanical injector though, since they are talking about multiple injections per cycle.
Old 09-28-2010, 04:36 PM   #6 (permalink)
UFO
UFO's Avatar
I would think it's a common rail injector with a piezo-electric actuator. They run extremely high pressure, around 20k psi, and are very sensitive to lubricity. The new VW TDIs are common rail and are currently experiencing a ton of premature injection pump failures. VW is trying to blame the customers for mis-fueling, but the US spec diesel fuel is not as lubricating as the EN spec, which the TDI CR is designed for.
At any rate, I think you could add about 5% biodiesel to pump gasoline, get a seriously lowered octane and highly lubricating fuel that might work well in this application.
Old 09-28-2010, 06:00 PM   #7 (permalink)
"The new VW TDIs are common rail and are currently experiencing a ton of premature injection pump failures."
A friend of mine is a retired GM mechanic and he told of a TSB that came out for the GM diesel back in he 80's. They too were having a lot of injector problems and were tired of replacing injectors that worked fine back in the lab. Their direction was to run a quart of ATF through the engine before testing. He said that it "cured" about half of the problems. The ATF provided detergent to clean any stuck on deposits and enough lube to keep the injectors from sticking. He said that he has done it to 100's of FE gas engines since and that it usually solves the injector problem. Just FYI.
Old 09-28-2010, 06:16 PM   #8 (permalink)
Bus - '94 School Bus huge
Stupid - '01 Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Superhawk
are they not using direct injection nozzles in gas HCCI engines already?
Old 09-28-2010, 08:38 PM   #9 (permalink)
Scania has been making a ethanol fueled engine that runs on the diesel cycle for some time now.
1951 Diesel Beetle ~~~ 40MPG Laurentiu The Lounge 3 07-23-2010 04:43 PM
The First Three Diesel Passenger Cars Laurentiu The Lounge 0 07-03-2010 09:40 AM
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 27 06-07-2010 07:49 PM
Poll for Americans: What about Diesel engines? hal9999 General Efficiency Discussion 117 01-07-2009 07:23 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
