Old 08-06-2013, 10:34 AM   #61 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Well, I wasn't able to make an idiot proof part:
  • I mixed/brushed on epoxy over the foam (maybe 2 coats);
  • then sanded it and finished with bondo and spot putty;
  • then high fill primer/sand/prime/sand/prime.
It was quite a respectable looking job after priming.
But since then I had bubbles appear in the finish. I hate doing finishing work.
aerohead (08-08-2013)
Old 03-13-2014, 12:13 AM   #62 (permalink)
Maybe I missed the post, but how did you end up mounting the lower block? Did it end up being no tools/removable like you wanted? I'm working on one for the vx now...
Old 03-15-2014, 09:30 AM   #63 (permalink)
The lower block was a no-tools installation/removal part.
The part was shaped to fit snugly in the lower opening. I attached bungee cords to the backside of the block and ran the cords straight back through the grille slats, then turned a 90 degree corner, upward to the rad support crossmember where I hooked them on.
That said, I never had to remove the part for cooling reasons.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (03-15-2014), gijoe985 (03-15-2014)
