Old 09-23-2010, 09:47 AM   #1 (permalink)
Making an educated guess of Cd.
It started out at .32, I have before and after coast down times. How do I calculate/guesstimate delta?
Old 09-23-2010, 05:17 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Good question, I think it has been answered before, but I want to see it as well.
Old 09-23-2010, 05:33 PM   #3 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Here's the Instructables page on doing a coastdown test:
Measure the drag coefficient of your car
Old 09-23-2010, 09:30 PM   #4 (permalink)
this is not what I asked for. I have seen this before, but too much is assumed with this chart, things I do not know, or have any way to find out. I know the Cd of my car before mods. I just want to know delta (change), from there I can calculate the new Cd. this would be far more accurate than guessing all the variables that this chart assumes you know for certain.
Old 09-23-2010, 09:37 PM   #5 (permalink)
Wiki Mod
for a rough idea, the % longer of coast down is ~= to $ better Cd.
Example: you coast 5% longer now = 5% better Cd or a change from .32 to .304 Cd
Old 09-23-2010, 09:38 PM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Actually, it is. You need to calculate your CRR before you can get anything useful out of coastdown data. A high-speed and a low-speed coastdown test, on the same road, on the same day, in both directions, is the way to go.
Or you could just look at the difference in coasting distance and decide whether the mod had a measurable impact or not.
Old 09-23-2010, 09:42 PM   #7 (permalink)
Left Lane Ecodriver
Ehh.... I don't think that's accurate. Suppose I coast 50% farther. Does that mean I reduced my drag from 0.25 to 0.125? And if I coast 100% farther?
If you drive really fast so that aerodynamic drag dominates (see the calculator to determine exactly how fast), and hit the clutch, the rate at which you slow down (mph per second) should be fairly linear with CdA. But the mph disappear too quickly to accurately measure when you hit the clutch at 74mph.
Old 09-23-2010, 09:45 PM   #8 (permalink)
Wiki Mod
True but it is just a "rough" idea for small changes. It is just another way of saying this mod helped or did not.
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 07:45 AM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
Cd change for irreversible mods Piwoslaw Aerodynamics 3 11-14-2009 04:50 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
