Old 04-06-2008, 01:12 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Making my own A pillar pods, how should I adhere these?
Im making my own A pillar pod using the stock trim and wanted to see if anyone had any recommendations for adhering these to the trim to its bullitproof
I'll post up some more pictures for a FAQ on how I made this..
reason I'm making my own is because a company called lotek I purchased one from and the guages aimed outside toward the window..
not for me, so I make my own
mine is going to hug the A pillar closely..
So if you guys could give me some ideas of how to make this work the best, that would be greatly appreciated..
I believe the black plastic is ABS..
Old 04-06-2008, 01:19 AM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I use Polyurethane for nearly everything, because it works with nearly everything, you can get it in black as well, I tend to get the black polly roof caulk, because it holds up to heat well.
Old 04-06-2008, 05:01 AM   #3 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
If you want them removable, I'd figure out a way to bolt them from inside the trim piece.
If not, then I would use some of the left over epoxy from your tonneau project. Attach the pod with a fillet of epoxy and fiberglass tape, sand, paint, done...
P.S. I love watching all your projects. Your ability to get stuff done amazes me...
- LostCause
Old 04-06-2008, 09:45 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Heres a write up by a guy on another forum I visit. Looks pretty good IMO.
http://board.tercelonline.com/viewthread.php?tid=25732
Old 04-06-2008, 07:49 PM   #5 (permalink)
EcoModding Minded
Chris D.'s Avatar
Thats sounds like it has some potential..
- LostCause
nah, fixed position is what i'm aiming for, a clean one piece look is what I like..
- LostCause
Thanks man, I couldnt have done it without the internet and search
That turned out pretty darn good..
I like his results..
I'd like to figure out how to replicate texture too..
Old 04-06-2008, 08:02 PM   #6 (permalink)
CM400E - '81 CM400E
This is actually my gauge pod project. Its a bit more involved so I didn't bother posting it. What I'm doing to keep the textured surface is using a wrinkle paint. Its not exactly the same texture as the rest, but its the closest I could find.
Old 04-06-2008, 08:39 PM   #7 (permalink)
EcoModding Minded
Chris D.'s Avatar
VERY NICE!! jet fighter cockpit style!
I was thinking for the texture you could use a build up primer and press a grainy section of leather against it while its tack.. Just an idea..
Old 04-06-2008, 10:36 PM   #8 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
IMHO Attach it however you need, then cover it with either fabric, vinyl, or leather.
A few pieces on the golf are sprayed with Spray on bed liner. works out OK, but not great.
6 speed ALH TDI
Old 04-06-2008, 10:55 PM   #9 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
IIRC, you can buy texture paint...I believe it goes on like a primer
If you're going to paint (and not wrap with cloth).... Do try and avoid gloss paints... look for more of a satin or matte finish (buy some samples and try to match).... Nothing kills the aesthetics more than having one gloss panel when the rest have a satin finish
Challenge me, or correct me, but don't ask me to die quietly.
Old 04-06-2008, 11:13 PM   #10 (permalink)
6 speed Diesel FTW!
Diesel
texture paint does go on similar to a thick primer, very dry. Bear in mind that it doesn't hide imperfections nearly as much as you would think.
Check out the Fabrication forum at MP3car.com for lots of ideas, but be warned they are the ones that convinced me a 15" tft would fit in a mkiii supra.
http://www.mp3car.com/vbulletin/fabrication/
6 speed ALH TDI
