Old 04-11-2009, 09:33 PM   #11 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Originally Posted by dcb View Post
Hmm, I wonder what happens if you have an engine brake with a centrifugal clutch? If you can get the engine to stop and if the clutch will still slip a little then the springs should pull the shoes back. Maybe? Break something? Maybe?
I shut the engine down when I decelerate, and the clutch holds very firm until the ~15mph drop-off point.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 04-11-2009, 09:42 PM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Well, I was thinking of physically stopping the engine (i.e. add a brake or possibly an early combustion event or something) while rolling and seeing if the clutch would slip and disengage. And if so how smooth would it be. IF that unit is spinning clockwise it might just slip as the housing is overdriven relative to the engine output shaft.
Old 04-11-2009, 10:09 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
there might be a more logical place disengage in the cvt too, got any exploded diagrams of the bergman tranny?
Old 04-12-2009, 09:43 PM   #14 (permalink)
Max - '01 S-10 LS
Well, not on the wheel side of the clutch that I can tell.
It won't seem to let me link directly to it, but if you go to Ron Ayers Motorsports, Hover on OEM Parts > Online Microfiche, choose Suzuki scooters then 2006 > Burgman 400,S > Transmission 1 & 2, #2 shows the post-clutch section, 11 being the shaft that the wheel hub is pressed onto, and 1 being the shaft that goes, I believe to the clutch housing. #1 shows the clutch and CVT section.
Jamming the engine is most likely going to cause a momentary rear wheel lock, the clutch does NOT want to slip at all above 15mph.
Old 04-14-2009, 12:48 AM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, I think I get it. This helped too and some googling on variators:
Just thinking out loud,
1. Maybe a longer belt with a spring loaded, lever controlled, idler pully on the bottom? So that you squeeze the lever and it adds a bunch of slack to the belt that the pulleys can't take up completely?
2. integrate a freewheel into the outside of the clutch housing? (bearing on the outside makes it tough).
Old 05-27-2009, 12:12 AM   #16 (permalink)
Ptero's Avatar
Smart Car ForTwo Pure - '08 Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 V12
Wildfire 250C - '08 250C
Overrunning Clutches
This is the Formsprag Clutch Application Manual for Overrunning Clutches.
It will teach you everything you don't already know about sprag clutches and allow you to choose the proper sprag clutch for your application, from bicycles to motorcycles to cars and trucks. It is such an excellent resource that I printed it out, all 52 pages, and mounted it in a 3-ring binder. Then I slobbered all over it. Joy! Oh, joy! It's an ecomodding miracle!
http://www.formsprag.com/litportal/pdfs/P-1052-FCLO.pdf
Old 05-29-2009, 09:09 PM   #17 (permalink)
Max - '01 S-10 LS
1 is right out, I'm afraid. Despite how it looks in the video, the pulley's pull on the belt HARD. The rear pulley is actually fighting the front pulley for gear ratio. Both would snap hard at the belt if it suddenly lost tension. Also, the belt would have to be held disengaged, as the clutch would remain locked up, along with the rear pulley.
2 gives me pause for thought. I can't for the life of me think of a design, but it is possible. Perhaps a video showing the inner workings of a free-wheeling clutch are in order?
Edit: OTOH, Ptero just posted a link that I need to investigate.
Old 05-29-2009, 10:38 PM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
Lol, I can imagine ptero closing the drapes and reaching for his 52 page binder now
Heres some half-bakery for ya:
mount another wheel a few inches to the right of the rear wheel, so that it almost touches the ground. When you want to coast just lean the whole bike onto that wheel and coast
Old 05-29-2009, 11:32 PM   #19 (permalink)
Max - '01 S-10 LS
By half-baked I assume you're speaking of yourself?
Your suggestion defies several of the laws of physics to which motorcycles are wont to obey.
Old 05-29-2009, 11:44 PM   #20 (permalink)
dcb
needs more cowbell
dcb's Avatar
It does no such thing. You can ride a three wheeler on two wheels, you can ride a 4 wheeler on two wheels. Put training wheels on your bike and balance on one of them to coast (have fun in the corners)
Reviving a 2000 Honda Insight "beater" Red Hybrids 201 01-06-2012 12:42 AM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 03:34 PM
Manual Cars and Popping the Clutch (to re-start engine) brekko Hypermiling / EcoDriver's Ed 31 12-15-2008 09:57 PM
