Old 04-06-2009, 10:19 PM   #1 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Manual disengage for a centrifugal clutch
My Burgman has a centrifugal clutch, and I'm trying to think up a way I can manually disengage it at speed.
I won't have a good idea of what to do until I have the clutch in my hands, but I'd like to know if anyone knows of an easy way to force a centrifugal clutch to disengage while at speed.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 04-06-2009, 10:40 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I've wondered about that myself. Other options might be to replace it with a manual clutch somehow. Or put a heavy duty freewheel on the rear sprocket maybe.
Old 04-07-2009, 09:51 PM   #3 (permalink)
Max - '01 S-10 LS
No rear sprocket here.
The engine crankshaft goes into the CVT, the CVT exits into the clutch, and the clutch drops straight into a fixed gear reduction drive which feeds the rear wheel directly. There's no sprockets anywhere.
Old 04-07-2009, 11:42 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
A free wheel on the engine or wheel side, either one would work but would be some machining to get it done, your wheel is a side mount wheel on the rear, right? make a free wheel that goes between the wheel and the drive shaft.
Old 04-08-2009, 09:38 PM   #5 (permalink)
Max - '01 S-10 LS
I'm a day-dream engineer, not a real one.
I really can't see a way to make it happen, as the wheel is more like a cars', with 3 lug bolts, and the bit with the lugs is on a splined shaft.
Old 04-08-2009, 11:21 PM   #6 (permalink)
Ryland's Avatar
So what you need is a free wheel that goes between the hub of he wheel and the drive hub, the walk behind tractor compeny BCS makes a free wheel hub retro fit for their tractors so you can turn sharper, it has a wheel bearing in it and a free wheel that protrudes through the hub of the wheel, you just bolt it on before you bolt the wheel on.
Old 04-10-2009, 10:38 PM   #7 (permalink)
Max - '01 S-10 LS
I honestly can't picture what you're describing.
Old 04-11-2009, 10:16 AM   #8 (permalink)
Ryland's Avatar
you need to get your free wheel between your drive wheel hub and the spider that the wheel bolts to, so it would look kind of like a wheel spacer, only it would have the free wheel in it, your wheel uses more then one lug to bolt on, correct?
Old 04-11-2009, 11:04 AM   #9 (permalink)
Max - '01 S-10 LS
Now I think I'm getting the picture, but I still can't picture HOW it would fit there. The rim bolts to the hub with 3 lugs.
I'll have to take some photos when I have it torn down next week or so.
Old 04-11-2009, 11:54 AM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
Hmm, I wonder what happens if you have an engine brake with a centrifugal clutch? If you can get the engine to stop and if the clutch will still slip a little then the springs should pull the shoes back. Maybe? Break something? Maybe?
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 02:34 PM
Manual Cars and Popping the Clutch (to re-start engine) brekko Hypermiling / EcoDriver's Ed 31 12-15-2008 08:57 PM
