Old 01-17-2010, 08:46 PM   #1 (permalink)
Driving the TurboWeasel
Marvel Mystery Oil Users?
I've been using Marvel Mystery Oil in my gas for the past 6 or so months, and have to say, it's made a bit of a difference in cold weather. The car's fuel system is quieter. The engine is knocking less, as seen on my ScanGauge set to display the timing pulled when the computer detects knock. Fuel economy data is unknown, but likely good. 33 mpg highway on my last big trip isn't too shabby, especially considering the 20* F weather the whole way.
2012 Chevrolet Cruze Eco 6MT
Old 01-17-2010, 11:01 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
What's in it?
Old 01-17-2010, 11:04 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
MMO is tranny fluid.
Old 01-17-2010, 11:27 PM   #4 (permalink)
Johnny's Metro - '93 Metro 4-Door Hatchback
90 day: 47.5 mpg (US)
Nope, not transmission fluid. It is Mineral Spirits 20-30%, with Napthenic Hydro-Carbons 70-80%, and Chlorinated Hydro-Carbons 0-1%.
With of course the secret ingredient that makes it smell so good and makes you always want more!
http://www.turtlewax.com/res/msds/MM010-4.pdf
Edit: Lubricity wise, it's not all that great. Going by a independent diesel additive lubricity study, Marvel Mystery Oil made no significant difference in the lubricity of Ultra Low Sulfur Diesel. So it probably has about the same lubricity properties of ULSD diesel. Still more lubrication than gasoline though!
Old 01-18-2010, 12:08 AM   #5 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
I use it...
right before doing oil changes on my moms Rav4 with 150k miles that she thrashes
(i got a half gallon for free too)
http://en.wikipedia.org/wiki/Marvel_Mystery_Oil
copied from another source:
Marvel Mystery oil is 30% varsol (charcoal lighter fluid) and 70% 30wt base oil some red dye and wintergreen fragrance. It is from the late 1920s.
Its a solvent type product. Some people find it beneficial for sticky valves or some sludge dispersal. If you are depending on them for either of these reasons, you have bigger problems.
It evaporates within hours in an engine. I neither provides any corrosion protection or anti-wear benefit. It will not harm anything in the recommended concentration.
Past Present Future?
Old 01-18-2010, 01:00 AM   #6 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Well I don't know about "bigger problems". My Vair sits for years at a time; once when I finally got the urge to go run it, it had a ticky lifter. Dumped some Seafoam in there an voila! freed it up. So sometimes- not often though?- additives serve a useful purpose.
Old 01-18-2010, 06:36 PM   #7 (permalink)
Hmm, didn't know about the evaporation part. It seems to stay in an opened bottle in my trunk for weeks at a time pretty well.
Even if it doesn't improve lubricity of diesel, it's likely okay for gasoline lubricity like you said. We definitely need the help with E10 since ethanol isn't a lubricant.
Old 01-18-2010, 07:37 PM   #8 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
I use it on every oil change and in the fuel for 2 years now. Have not noticed any difference in fuel mileage.
"Judge a person by their questions rather than their answers."
Old 01-18-2010, 08:05 PM   #9 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I personally wouldn't use it in oil except as a purge.
I do use it in all my vehicles FUEL as I do see improvements in FE on most of them including my diesels. The dodge crewcab however isn't affected
MMO also helped me run a 98 Buick lesabre with a blown intake for 2yrs. before my father rev'd it in 2nd up to 80mph passing and blew out the engine anyway I still wonder why all the garages kept saying there was NO issue with the car? That was apparently a pretty common issue to have the plastic garbage leak radiator fluid inside the heads.
It also helped a 93 suburban run that would miss terrible without it.
Old 01-19-2010, 09:45 PM   #10 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
My dad used this stuff all the time in his gas. I used it in my manual transmission along with the synchromesh only to clean it out before changing the fluid.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
Filling oil just to min line? better mpg? Fr3AkAzOiD EcoModding Central 36 04-17-2010 10:58 AM
