Old 10-26-2010, 11:46 AM   #121 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Rokeby, the first two are hard to tell without side view. But the last one
looks promising in front. Imagine it with Prius rear...
Cheers
KB
Old 10-26-2010, 12:53 PM   #122 (permalink)
RSX2fast4mpg - '02 RSX Type S
90 day: 37.22 mpg (US)
bubbatrucker - '98 K1500
90 day: 18.1 mpg (US)
You can't tell whether that Mitsu is coming or going without a doubletake.
This thread has really got me thinking; maybe we're doing it wrong. Rather than trying to add kammbacks and boat tails, perhaps we should be starting with a reasonably aerodynamic minivan and chopping the back so it can be sloped back. Of course, most vans start with engines that are way too large because they want power for cargo, but design-wise, it might be the place to start. Or maybe a Scion Xb?
Imagine cutting from behind the front door and tapering it back to a boattail.
Starting with a smaller, reasonably good mileage vehicle and chopping it off behind the front door.
I don't do photoshop, but use your imagination.
Old 10-26-2010, 01:03 PM   #123 (permalink)
But a van has a LOT more frontal area than a car
Old 10-26-2010, 02:22 PM   #124 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Protege5
90 day: 32.52 mpg (US)
wouldnt that support the "teardrop" shape better though ?
~Mike
Old 10-26-2010, 03:39 PM   #125 (permalink)
That's what I thought, especially if you lowered it and chopped the top. The problem is obviously structurally altering a unibody chassis, thus losing all strength. While adding boattails do little to reduce strength and may actually increase crumple zones, chopping the top off your minivan and removing everything down to the floor toward the back is going to make you extremely vulnerable in a rear impact.
Also, to get good mileage, you need a smaller engine; ideally a 1.5L or so and most minivans are sporting a 2.2-2.8L.
Old 10-26-2010, 08:18 PM   #126 (permalink)
Gen II Prianista
Rokeby's Avatar
Is there a reason why in discussions of adding a boat tail to achieve
a more nearly teardrop shape the VW Bug in never mentioned?
The front end appears to have the roughly "cab-over" design that helps
get the high point well forward. The rear however needs lots of help...
I would think a boat tail candidate for sure.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 123 07-25-2011 09:24 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Video: clever, simple demo of teardrop shape -pointy end first vs. blunt end first MetroMPG Aerodynamics 10 03-12-2009 08:48 PM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
