View Poll Results: What will the results of A-B-A testing show?
Reduced drag vs. normal grille block 57 48.31%
Increased drag vs. normal grille block 23 19.49%
No significant change 16 13.56%
AAAAAHHH! MY EYES!! 42 35.59%
Multiple Choice Poll. Voters: 118. You may not vote on this poll
Old 08-19-2009, 08:05 PM   #11 (permalink)
ForkenSwift - '92 Geo Metro EV
Last 3: 95.68 mpg (US)
90 day: 50.45 mpg (US)
Oh yes, the Crisis Fighter Pinto! I forgot about their massive air dam. (So much info passes in one eye and out the other...)
From the Car and Driver report:
For maximum effectiveness, this one was designed with only two inches of ground clearance and as much of a wedge contour as possible to split the air in front of the car
At seventy mph, that simple sheet of aluminum added 0.9 miles per gallon to our test Pinto. [From 14.5 mpg unmodified, at 70 mph]
EcoModder blog: Crisis Fighter Pinto
Latest mods test: 15 mods = 15% MPG improvement: A-B test, 2007 Honda Civic 1.8L, 5-speed
Ecodriving test:
Manual vs. automatic transmission MPG showdown: Nissan Micra 1.6L
Old 08-19-2009, 08:11 PM   #12 (permalink)
PokÚmoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
MetroMPG -
The Pinto is what I was thinking about also :
( 14.5 + 0.9 ) / 14.5 = 1.062 => 6.2% Improvement @ 70 MPH.
CarloSW2
American Solar Energy Society
Old 08-19-2009, 08:35 PM   #13 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
90 day: 19.68 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
90 day: 20.6 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
90 day: 21.28 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
90 day: 20.56 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
90 day: 20.54 mpg (US)
BZP T-100 current (2017) - '98 Toyota T-100 SR5
90 day: 19.38 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
What kind of support do you have on the bottom edge? I dropped my air dam really low with coroplast and the bottom edge had a tendency to fold in/over at higher speeds...especially when the air got dense with humidity.
Old 08-19-2009, 08:58 PM   #14 (permalink)
There's nothing running the full width of the bottom edge, but there are 4 folded V-shaped vertial wedges/braces supporting the face of the dam against the OEM bumper. Sort of like this:
The curved sides of the dam are reinforced at the bottom edge by a wide lip on the inside that goes from the outermost of the 4 braces, around to the edge of the wheel arch.
I've taken it up to 100 km/h so far, with no visible deformation ... only checked afterwards, though. I didn't rig my web cam for a live view.
Ecodriving test:
Old 08-19-2009, 09:01 PM   #15 (permalink)
I just realized the braces would be damaged if they hit something low down. I mean.. if they weren't cardboard... assuming a "good" version of this were made.
Better to have slightly shorter braces, and some sacrificial Home Depot lawn edging as the lowest point of the dam that could take a hit.
Ecodriving test:
Old 08-19-2009, 09:25 PM   #16 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
Galaxy 2 - '06 Honda Civic Hybrid
90 day: 36.29 mpg (US)
so are the results in?
or are we still polling
Past Present Future?
Old 08-19-2009, 11:27 PM   #17 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I think you're going to get called a ricer. I can feel it. Someone is going to mistake that as a lame attempt at reproducing a body kit....
"┐ʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 08-19-2009, 11:27 PM   #18 (permalink)
Ricer. :P
Old 08-19-2009, 11:59 PM   #19 (permalink)
I still can't get over a 4-banger Pinto only getting 14.5mpg. My 4x4 V8 F150 does better than that unless I'm towing. Used to have an F250 4x4 with a 460 V8 that got 13-14 NO MATTER WHAT. There is something wrong with this equation.
I don't remember them being THAT bad, 70 mph notwithstanding.
I got around 20ish with my 283 V8 a/t equipped Nova- supposed to be 55mph but often was closer to 70.
Was their car messed up?
Old 08-20-2009, 12:05 AM   #20 (permalink)
Grasshopper
im sure if i pull up to a light and rev
someone would call me a ricer
*shrugs*
My Geo Metro Air Dam Mod Hacksaw EcoModding Central 20 01-20-2010 10:32 PM
Metro air dam 900Z1 Aerodynamics 4 04-26-2009 01:29 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 10:30 PM
Metro air dam Metro502 Aerodynamics 4 07-24-2008 05:44 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 11:15 PM
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
