View Poll Results: What will the results of A-B-A testing show?
Reduced drag vs. normal grille block 48 46.15%
Increased drag vs. normal grille block 21 20.19%
No significant change 15 14.42%
AAAAAHHH! MY EYES!! 40 38.46%
Multiple Choice Poll. Voters: 104. You may not vote on this poll
Old 08-19-2009, 08:05 PM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Oh yes, the Crisis Fighter Pinto! I forgot about their massive air dam. (So much info passes in one eye and out the other...)
From the Car and Driver report:
For maximum effectiveness, this one was designed with only two inches of ground clearance and as much of a wedge contour as possible to split the air in front of the car
At seventy mph, that simple sheet of aluminum added 0.9 miles per gallon to our test Pinto. [From 14.5 mpg unmodified, at 70 mph]
EcoModder blog: Crisis Fighter Pinto
Old 08-19-2009, 08:11 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
MetroMPG -
The Pinto is what I was thinking about also :
( 14.5 + 0.9 ) / 14.5 = 1.062 => 6.2% Improvement @ 70 MPH.
CarloSW2
American Solar Energy Society
Old 08-19-2009, 08:35 PM   #13 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.88 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
What kind of support do you have on the bottom edge? I dropped my air dam really low with coroplast and the bottom edge had a tendency to fold in/over at higher speeds...especially when the air got dense with humidity.
Old 08-19-2009, 08:58 PM   #14 (permalink)
There's nothing running the full width of the bottom edge, but there are 4 folded V-shaped vertial wedges/braces supporting the face of the dam against the OEM bumper. Sort of like this:
The curved sides of the dam are reinforced at the bottom edge by a wide lip on the inside that goes from the outermost of the 4 braces, around to the edge of the wheel arch.
I've taken it up to 100 km/h so far, with no visible deformation ... only checked afterwards, though. I didn't rig my web cam for a live view.
Old 08-19-2009, 09:01 PM   #15 (permalink)
I just realized the braces would be damaged if they hit something low down. I mean.. if they weren't cardboard... assuming a "good" version of this were made.
Better to have slightly shorter braces, and some sacrificial Home Depot lawn edging as the lowest point of the dam that could take a hit.
Old 08-19-2009, 09:25 PM   #16 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
so are the results in?
or are we still polling
Past Present Future?
Old 08-19-2009, 11:27 PM   #17 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I think you're going to get called a ricer. I can feel it. Someone is going to mistake that as a lame attempt at reproducing a body kit....
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 08-19-2009, 11:27 PM   #18 (permalink)
Ricer. :P
Old 08-19-2009, 11:59 PM   #19 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I still can't get over a 4-banger Pinto only getting 14.5mpg. My 4x4 V8 F150 does better than that unless I'm towing. Used to have an F250 4x4 with a 460 V8 that got 13-14 NO MATTER WHAT. There is something wrong with this equation.
I don't remember them being THAT bad, 70 mph notwithstanding.
I got around 20ish with my 283 V8 a/t equipped Nova- supposed to be 55mph but often was closer to 70.
Was their car messed up?
Old 08-20-2009, 12:05 AM   #20 (permalink)
Grasshopper
im sure if i pull up to a light and rev
someone would call me a ricer
*shrugs*
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/massive-cardboard-air-dam-geo-metro-b-coastdown-9732.html
Posted By For Type Date
A.M.E.C. Message Board :: A.M.E.C. Main Forum :: AMEC Economy Run events thread ~ Runboard This thread Refback 03-26-2010 03:36 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 12:29 PM
1998 Metro High MPG This thread Refback 11-29-2009 01:04 PM
My Geo Metro Air Dam Mod Hacksaw EcoModding Central 20 01-20-2010 10:32 PM
Metro air dam 900Z1 Aerodynamics 4 04-26-2009 01:29 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 10:30 PM
Metro air dam Metro502 Aerodynamics 4 07-24-2008 05:44 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 11:15 PM
