Old 11-05-2009, 05:58 PM   #71 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
List-o-mods suggestion:
Have had great success with my TCC lockup switch. Increase over two full tanks was 20%. Went from 24mpg (4 tanks) full tank average to 29mpg. (2 tanks)
I figure that's worth the 10 minutes it took to wire. It takes some getting used to driving with it but it's more fun.
Biggest gains would be had in hilly country.
Old 12-03-2009, 09:53 PM   #72 (permalink)
I've heard of this switch but I've never read a report from someone who used it; thanks!
Old 12-03-2009, 10:51 PM   #73 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
It's on the list to add to the list. Been on it for a while, actually.
(Tackling the list is on another list...)
Old 12-03-2009, 10:53 PM   #74 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
That would be the list that contains all the lists of things that need to be listed. In list format, of course.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 12-04-2009, 12:55 AM   #75 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
"Give me a list long enough and a forum on which to place it, and I shall mod the world."
- Marchimedes
Old 12-30-2009, 01:52 AM   #76 (permalink)
few comments on the write-up (and things I haven't seen in the responses)
side mirrors are a big aerodynamic issue on most cars. rather than deleting them for legal reasons, substitute them with motorcycle racing side mirrors... There are many choices.
Overdrive pulleys for the water pump, power steering pump, alternator; AND/OR an underdrive crank pulley. I see alot of confusion with people saying over-drive or under-drive. Over-drive is a larger pulley you put on any accessory to make it spin slower. Under-drive is a smaller pulley you would put on the crank to make the whole belt assembly spin slower as a whole. Electric pumps are all great but its a whole 'nother drug. I don't hear alot of success stories, and it always seems to be costing someone alot of money (ZOMG my coolant pump lost siphon and my engine locked up).
weight reduction isn't as much of a mpg gain as it would seem. aerodynamics plays into effect much more than weight does at a constant cruise speed. The weight reduction gains that are maximized are by reducing the rotating mass and the unsprung mass. Light rim/tire combos along with 2-piece rotors. It makes a difference in the power you put to the road. Gutting your car on the otherhand does not make that much of a difference.
wheel bearings and alignment. you don't have to wait for squealing noises before you replace some of this stuff.
Old 12-30-2009, 04:00 AM   #77 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I like the idea of an underdrive pulley slowing the whole works down, but that is tempered by the knowledge that the tighter you bend chains/belts on small sprockets/pullies, the less efficient the power transfer system becomes. So then you must decide if the gains from slowing the driven stuff down overcome the loss from bending that belt tighter. They probably do, but still it sux to ADD inefficiency to get efficiency
Old 12-30-2009, 04:04 AM   #78 (permalink)
The belt radius could be overcome by increasing the diameter of both pulleys, but this exacerbates the issue by adding angular momentum and increased rotating mass.
Darn it all.
Well, maybe if you replaced them with bigger aluminum pieces with a lower turns ratio, you could defeat both issues, but then there is still the angular momentum issue caused by the larger radius of the pulleys. Darn Darn Darn!
Old 12-30-2009, 04:07 AM   #79 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
I KNOW!!!
So instead of worrying about all that jazz, I just keep the rpms low and the accessories off.
Old 12-30-2009, 04:08 AM   #80 (permalink)
SUNUVA!!! You might be on to something, Frank!
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 264 02-03-2012 09:51 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 12:57 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
