Old 11-24-2011, 10:43 AM   #11 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
You may not have to do O rings if you insulate it. I've heard of people using housing-grade fiberglass insulation to block against exhaust heat. I've sandwiched crushed aluminum pop cans between my muffler and rear belly pan and have had no problems. Crude I know, but also cheap and effective.
Also for oil changes and such consider what the EV1 used: access holes. Lots of them.
CCS's EV1 by Tyler Linner, on Flickr
You could always build in little hinged doors too but that would be splitting hairs. Remember, in the grand scheme of things, a softball sized oil drain hole in your belly pan doesn't really matter that much.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 11-24-2011, 12:17 PM   #12 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
That's clever, both answers to the heat problem. Filed. Thanks.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
