Old 07-19-2010, 09:43 PM   #1 (permalink)
Zerohour's Avatar
Pooparu - '01 Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '011 Cooper
90 day: 36.4 mpg (US)
People Power - '86 Not Slim
90 day: 5.45 mpg (US)
Materials Question
So I have this 2001 Subaru Outback Sedan, and I've decided to play ecobug for a while to see who much fuel sipping I can get out of it.
I see alot of people have modified bumpers and the sorts and I would love to do the same.
I've done some trolling unregistered and I know there is a Subaru Outback Wagon on patrol here as well.
My first big question is, what do you use to construct body modifications? Thin sheetmetal gets heavy fast. And you can't build everything out of cardboard.
I have fairly creative with fiberglass, but that stuff is nasty. I've also looked at vaccuum forming for smaller aero pieces, but I am under where to get the plastic sheets used.
I am wondering, what do all the cool kids build there aero bits out of?
Old 07-19-2010, 10:09 PM   #2 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
I think Coroplast is the #1 material. It's used a lot for making political and other temporary signs.
Old 07-21-2010, 06:30 PM   #3 (permalink)
masking tape and cardboard proof-of-concept
Zero,you might consider making a working mock-up out of cardboard and masking tape and run it long enough to evaluate any contribution it might make.
Then,it it warrants it,you can commit to a permanent build.
Old 07-22-2010, 06:38 PM   #4 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Meh its hard to use cardboard when we're in the rainy portion of summer. It takes me about a week to use a tank of gas, and I would like to slap on 4 aero pieces in the first go. Well Five Aero pieces, 4 are fiberglass products (in my mind at least).
The coroplast seems like an interesting way to build forms for fiberglass though. I am wonder where is a good place to source or individual pieces? I did some quick search and I can buy it by the pallet, but thats a little excessive.
I also know there is a certain type of hobby plastic that works well for vacuum forming, but I need to look that up again. I think vacuum forming over some simple carved foam shapes will yield an item that is replaceable (stones, birds, jackass in parking lots). Not to mention lightweight as well!
Old 07-23-2010, 06:56 AM   #5 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Zerohour, you don't need to run a full tank. Think quick test. Coast down curves can give a good indication of whether a change is making any difference aerodynamically. ScanGauge (et al) also enable cost effective experimentation such as Darin's recent cross posts on mpg vs speed curves. My SG paid for itself Year 1 with fuel savings BTW.
Cheers
KB
Old 07-23-2010, 08:26 AM   #6 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Check with yer local recycling place...they might have some coroplast they can give to you fer free.
I wonder how well fiberglass screen and the roll on bedliner stuff would do...
I've been using luan sheets as my lightweight, low cost, easy to git/work with material.
Old 07-23-2010, 01:24 PM   #7 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
For me, foam/fiberglass is the only way to go most of my mods concerning bodywork.
Honda Insight Under-body Smoothing Panels (custom belly pan / undertray)
Jim.
Old 07-23-2010, 03:13 PM   #8 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
I used shrink-wrap plastic for my grill block. The stuff you buy in the fall the put on the windows in your house to make poor mans storm windows. It's attached with 3M double sided tape and then use the hair dryer to stretch it tight. $1.79 at home depot for enough to do one house window. Yes -- if you run through the car wash you have to replace it but it has lasted me over 6 months. (I don't wash my car)
Old 07-23-2010, 04:15 PM   #9 (permalink)
Library= directories= source of vacuum-form plastic
A local library can provide directories for commercial business operations in your local.
Look for a business which deals with vacuum-formed ABS plastic sheet who will sell you small quantities.This sort of material is not sold retail and typically you must be a business to obtain it.It is sold by the pound.In 1986 it was about $2.35/lb.
An electric oven can be constructed at home,along with perforated wooden tooling affixed to a vacuum table.
A small air conditioning vacuum pump from a pawn shop can be used to charge an accumulator tank.A foot-operated air-valve will communicate the large volume of vacuum flow to the vacuum table.
Typically,the ABS is secured to a rigid framework,is pre-heated,then sent to the oven.When it achieves sag,it it quickly transferred to the table,quick-clamped down,all along it's periphery,then the valve is opened,drawing the plastic down over the tooling.
In about 30-seconds the part can be removed and taken to a router station where it is positioned over a trim-jig which guides the router,cutting away the flash.
Remember,you cannot have any straight,90-degree walls on your pattern.A certain amount of 'draft' is required for a proper 'release' after cooling or your part will stick.And freeing it can damage or destroy your precious tooling.
Old 07-23-2010, 05:46 PM   #10 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Lego.
After all Smart use it.
No longer here. Bye, and good luck to all.
Newbie Lean Burn question Liam EcoModding Central 2 04-04-2009 07:51 AM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 06:28 PM
Materials for Ecomodding bennelson EcoModding Central 19 05-31-2008 10:13 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
