Old 11-20-2009, 01:48 PM   #1 (permalink)
VW GOLF - '96 Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 AE50 Style
Last 3: 70.4 mpg (US)
Materials - Where to Get Coroplast un the UK
Hi there,
I am thinking of getting some Coroplast (called Correx in the UK) for an undertray. Instead of buying the pricey 4mm stuff from a signmaker I think I'm going to use 2 layers of 2mm black material like builders put down instead of ply these days.
It's around £4 - £5 a sheet (2.4m by 1.2m) from a local builder's merchant.
Trademate by Travis Perkins
(No association - other builder's merchants are available who may stock correx sheets)
I had to sign up for a cash account card (free) to buy it, but no fuss otherwise. I recon a whole undertray can be made for £20ish.
I will post a separate thread of the undertray / belly pan build when the time comes.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
The Following 2 Users Say Thank You to sallen For This Useful Post:
andylaurence (11-23-2009), Two_Weeks (11-20-2009)
Old 04-07-2010, 04:19 PM   #2 (permalink)
Someone knows where i can get coroplast on the other side of the channel? In holland i only see expensive transparant coroplast for around 40 dollar.
Old 02-15-2011, 06:54 PM   #3 (permalink)
mikee55's Avatar
I found a 4 foot square "For Sale" sign, beside some traffic lights Same material as House Estate Agents for sale signs!
Mike
Why is diesel so expensive in the UK? Eddles Off-Topic Tech 17 10-01-2009 11:50 AM
THE Best Coroplast For Flat Underbody Panels! Blue Bomber Aerodynamics 17 04-16-2009 05:53 PM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 01:27 PM
How to get coroplast home? Sean T. EcoModding Central 22 12-09-2008 01:00 AM
Tips for working with plastic, Coroplast, polycarbonate orange4boy Aerodynamics 0 08-30-2008 05:15 PM
