Old 01-06-2009, 03:07 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Matrix MAF sensor problem
When it is very cold out (about under 10F) the Matrix starts real rough for a few seconds and finally smooths out (I assume it goes into closed loop mode at this point). The check engine light of course has been turned on from this. Its a P0100 which is "P0100 Mass or Volume Air Flow Circuit Malfunction". So, I got a new MAF sensor last night and installed it right away. Well, this morning its cold out again and what do you know, it does it again. So, am I right in assuming that there is some problem with the wiring to the MAF sensor or something?
Old 02-12-2010, 12:23 AM   #2 (permalink)
My dad installed a new mass air flow sensor on his car because the check engine light goes on everytime and engine knocking, stalling and shuddering. But after installing it, the same problem occurs. He's thinking faulty wiring.. He's going to bring it to the shop later to have it checked.
Old 02-12-2010, 10:38 AM   #3 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I would check the pins in the plug for any corrosion, then check for any cracked insulation on the wiring going to the MAF connector.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 02-12-2010, 12:02 PM   #4 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
On TDI MAFs, filling the connector with dielectric grease has been known to fix certain connection issues,
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-22-2010, 08:35 PM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...anything "new" (hopefully successfull) to report?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 02-22-2010, 09:15 PM   #6 (permalink)
CM400E - '81 CM400E
Yeah, it wasn't the MAF sensor. My Matrix had been modified by the previous owner. He had installed a wideband O2 sensor in it to play around with it (with narrowband simulation). In order to fake the ECU into thinking that the original sensor was still in it, he added resistors into the O2 heating circuit to simulate the sensor to avoid the ecu detecting something wrong. Unfortunately, he didn't solder these connections and they began to come apart. I don't know exactly why this gave me a MAF code, but after I replaced the wideband with the OEM sensor again all was fine. Unfortunately, I had already replaced the maf sensor which wasn't too cheap.
Old 02-22-2010, 09:25 PM   #7 (permalink)
...beats walking...
...glad to hear "...all's well..." (now) inspite of the previous owner's "tinkering."
A new best tank for the Toyota Matrix: 48 MPG Daox Success Stories 10 09-24-2010 01:47 PM
Daox's 2003 Matrix Build Thread Daox EcoModding Central 74 09-17-2009 08:22 PM
Better Gas Mileage from my 06 Matrix thevisionseeker Hypermiling / EcoDriver's Ed 9 06-02-2008 04:11 PM
An inkling of what the Matrix is worth Daox Hypermiling / EcoDriver's Ed 12 06-02-2008 02:56 PM
MAF sensor life Daox Off-Topic Tech 9 03-25-2008 02:29 PM
