Old 10-13-2010, 03:06 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
MAX torque at 800rpm?!?!
I was just told that the 300 I-6 develops MAX torque at 1200 rpm, with 10° timing. I have mine set to 14°, so that would make it roughly 800 rpm, right? No wonder it pulls so hard at idle! I can climb real hills at 35mph in 5th gear!!! If I try to go faster on a steep hill, it just slows to 35! A change of timing might be in order.....
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 10-13-2010, 03:18 PM   #2 (permalink)
Thats sounds pretty low for gas engine .
I did Google search and came up with this, see if it fits your yrs .
Ford 300 Inline 6 Cylinder Specs, Ford 300 Engine Information, Firing Order : Engine Facts.com
Old 10-13-2010, 03:18 PM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
How do you figure?
Old 10-13-2010, 04:10 PM   #4 (permalink)
I was told that each degree of advance moves the torque curve down ~100 rpm. Is this not right?
I was poking around on other forums and found the 1200 rpm statement for my engine. I have no idea which forum it was. I know it is nowhere near 2000 rpm.
I run out of torque fairly quickly compared to what I used to have before the timing change.
1991 F-250:
Old 10-13-2010, 04:57 PM   #5 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Cam timing or ignition timing?
Old 10-13-2010, 05:14 PM   #6 (permalink)
I was told ignition timing....I assume that is wrong by the way you asked....
1991 F-250:
Old 10-13-2010, 05:31 PM   #7 (permalink)
Those general rules of thumb tend to apply to things near the "average" of whatever group the rule of thumb is supposed to apply to. Yours sounds like it probably isn't near the average.
You may not have moved the torque band down at all, in fact. Only a dyno will tell you for certain. The same goes for cam timing, BTW.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
IsaacCarlson (10-13-2010)
Old 10-13-2010, 10:06 PM   #8 (permalink)
turquoise - '97 Starlet
90 day: 41.46 mpg (US)
Cam timing will affect your toque band.
Ignition timing will do little if nothing.
Old 10-14-2010, 10:54 AM   #9 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
More ignition timing (up to the ideal point) generally equals more power at a given RPM, similar to more compression. Basically, it increases cylinder pressure when the plug fires. This can lead to a gain in low-end torque, but it shouldn't cause a loss of high rpm torque.
Advanced cam timing, however, moves the entire powerband down.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 10-16-2010, 01:04 PM   #10 (permalink)
I set the timing back to 10° today and test drove....I lost a lot of my low-end torque. I used to be able to smoke the tires on the driveway in third from idle....not with 10° timing. It starts quicker, and seems to drive "easier". The computer advanced the timing a LOT more with the base set at 14° than at 10°. The comp advances the timing to ~26° with 14° timing and only 15° with 10°....anybody know why? Shouldn't it be linear? Maybe leave the spout connector plugged in and see what it does when I change it?
1991 F-250:
Master list of 65+ proven mods for increasing MPG MetroMPG EcoModding Central 184 Yesterday 05:44 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
