Old 03-10-2011, 03:17 PM   #1 (permalink)
max water temp-scan guage
What should a peak water temp range to? I just got a scan guage a while ago and I have been wondering what the peak temp should be to maintain safe engine operation.
I closed off my wifes grille this winter when temps dropped below 0 and i havent opened any more than about a 4x4 inch hole at the bottom. the analog temp guage has never once budged above the half mark, but getting a digital readout on the scan guage suprised me how hot it gets.
the hottest i have seen it get is 203f. City driving usually averages around 185 +-10 depending on driving style.
97 civic mt.
Old 03-10-2011, 03:35 PM   #2 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
my jeep typically runs 190-200* in the city, and can get up to 206* on the highway going uphill. i don't see 203* being an issue in any way
Old 03-10-2011, 03:51 PM   #3 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I can give you some solid numbers on that civic.
The fan comes on at 206F and cools until it's below 200F.
The radiator isn't doing anything until the mid 180's when the thermostat opens.
Normal operating range is anything between those.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 03-10-2011, 04:08 PM   #4 (permalink)
thanks for the insight!
Old 03-10-2011, 04:47 PM   #5 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
Generally, as long as you're not over 210 - 220*, you're fine. 203* is certainly not an issue at all.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 03-10-2011, 10:17 PM   #6 (permalink)
vskid3's Avatar
Civic DX - '97 Civic DX
90 day: 34.15 mpg (US)
GTO - '04 GTO
90 day: 22.62 mpg (US)
My '97 Civic without a grille block and with the fan disabled hovers between 199 and 203F. Highest I've seen was 213F after winding through a parking lot for several minutes to find a spot. I have an alarm on my Ultragauge that is set to go off at 210F. If I know that I'll be moving to cool it down soon I just pay more attention to it until it cools. If for some reason I won't be able to cool it down passively, I can just jump out and put my jumper back in the fan.
