Old 10-28-2010, 08:13 PM   #1 (permalink)
Mazda, 70 mpg (~45 MPG per epa), without a Hybrid
Direct injection & 14:1 compression along with light weight body seems to be their answer.
70 mpg, without a Hybrid - Technology Review
Old 10-28-2010, 09:13 PM   #2 (permalink)
Polymorphic Modder
MorphDaCivic's Avatar
2006 DaCivic Hybrid - '06 Civic Hybrid
90 day: 45.16 mpg (US)
14:1 compressiion ratio is amazing! The article doesn't say but I bet the engine requires the highest octane pump gas. That is one reason I won't buy a gas volkswagen due to the premium gas requirement.
Seems like these great engines are released in Japan and Europe but never make it to the USA. Conspiracy theories this is your cue to comment....
Old 10-28-2010, 09:26 PM   #3 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Variable valve timing allows the effective compression (in cylinder actual) to be controlled with valve duration of both intake and exhaust separately. Variable lift would also allow for the same lower compression.
Direct injection also cools the piston head and cylinder head temperatures.
Higher rates of EGR are another way to control peak combustion temperature.
Fuel injected at TDC and even after TDC in multiple stages are another way to eliminate preignition, since preignition requires the air and fuel to be ignited before the piston reaches TDC. The peak combustion pressure can even be delayed past TDC when a combination of these strategies are employed.
regards
Mech
Old 10-29-2010, 07:18 AM   #4 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Next they should increase the compression to 25:1
Then it could handle lower grade fuel.
Oh and at that ratio, the spark plugs wouldnt be needed due to the high compression !
Now that would be efficient and powerful.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 10-29-2010, 07:24 AM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
According to my rough calcs, a 70 mpg rating in Japan is ~45 mpg EPA here. Pretty good, but I'll believe it more when I see it actually in a production car. You need more than engine tweaks to get there. Still, its great to see new technology like this.
Old 10-29-2010, 09:58 AM   #6 (permalink)
Interestingly, Mitsubishi's latest diesel engine has a 14.9:1 compression ratio. At this rate, gas and diesel engines will soon be running very similar compression ratios.
Mitsubishi 4N1 engine - Wikipedia, the free encyclopedia
Old 10-29-2010, 11:26 AM   #7 (permalink)
It sounds like Fiat's multi air engine which is already in production.
Test: Alternator vs. no alternator = 10% MPG gain @ 70 km/h MetroMPG EcoModding Central 212 04-08-2012 11:59 AM
Aeromodding in the 1930's: 38 mpg, 70 mph Model T MetroMPG Aerodynamics 38 06-18-2010 05:25 AM
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 36 04-01-2009 03:48 PM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 01:09 PM
GM's Tahoe SUV hybrid ad claims better MPG than Camry* MetroMPG Hybrids 4 12-19-2007 11:47 PM
