Old 08-24-2011, 08:51 AM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Mazda's Skyactiv-D (diesel) technology
Some interesting tidbits about Mazda's new Skyactiv-D technology. They're planning on replacing the current 2.2L with this new 2.2L which sports a 20% increase in fuel economy (they say it'll give 43 mpg on the hwy, no mention of what vehicle thats in). It has 14:1 compression ratio, the lowest of any passenger car diesel engine. It says that the lower compression ratio allows for better air/fuel mixing and optimized combustion timing. The article also explains how a higher compression ratio is needed for cold starts, but Mazda got around it by using variable lift on the exhaust valves. It keeps them open during cold starting to increase cylinder temps and thus the cold start ability. The lower compression ratio also lead to lighter weight components taking 6.6 lbs off the internal's weight. It also has an aluminum block which saves another 50 lbs over the previous engine.
Mazda ‘Reinvents’ Diesel With New Skyactiv-D
Old 08-24-2011, 01:34 PM   #2 (permalink)
euromodder's Avatar
Hδgar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
This reads like the best part :
"Because combustion is more uniform with a lower ratio, nitrous oxide and soot emissions are minimized, negating the need for an expensive aftertreatment system."
That could save a lot of costs and hassle.
I wonder wether it can run on 100% biodiesel - as the current generation of hi-tech diesels can't.
Lifetime fuel consumption :
Old 08-24-2011, 02:04 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...elimination of "add-in" urea is definitely a BONUS!
...addition of VVT to diesel is new.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
