Old 12-19-2012, 07:22 AM   #11 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
90 day: 52.81 mpg (US)
Tour bike - '011 Carp line Tour
C - '97 R40
tractor - '66 Cub cadet 129
Augie - '91 Corolla Wagon All-Trac DX
Y2K - '00 Insight
Hoping to get the exhaust valve today. Looks like we will get our first winter storm before it's reassembled.
- Tony
Old 12-23-2012, 08:24 PM   #12 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
Gaskets and exhaust valve arrived today. Not sure how I am going to check the valve seat.
- Tony
Old 12-24-2012, 06:26 AM   #13 (permalink)
Should be Playing WoW!
Bacon - '99 Forester L
Did you not have enough cars? Good luck!
Old 12-26-2012, 11:21 AM   #14 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
I decided not to mess with the old head, as the valve seat needs grinding and the adjustment requires shimming. I ordered a rebuilt head that comes with the cam shafts and valves all pre adjusted for $275 plus $20 shipping.
In for a dime, in for a dollar? Do I order new high compression 94 pistons rings and rod bearings? Will I find a Toyota engineering surprise when I try to disassemble the oil pan? OR should I just put the head back on.
http://www.scribd.com/doc/36969270/4A-FE-Cylinder-Head
- Tony
Old 01-02-2013, 06:20 PM   #15 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
The head finally arrived today. make me wonde4r if I sould have gotten a whole 1.5L japanese engine to swap in instead for a couple of hundred more.
- Tony
Old 01-06-2013, 09:48 PM   #16 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
Torqued the head down today.
- Tony
Old 01-08-2013, 09:44 PM   #17 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 19.36 mpg (US)
An interesting car. Never have seen one closely, ridden in one, or heard about it before now.
2004.0 DODGE Ram QC/LB 2500 2WD/NV-5600 305/555 ISB. 7,940-lb. Stock. 192,000 miles/4,900-hrs @ 39-mph average. 35' 9k GVWR TT. 14.6-cpm solo & 25-cpm towing; 21-mpg average past 44k-miles
Fuel Log
Old 01-12-2013, 11:19 AM   #18 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
Installed the cam shafts and timed it. It took a few tries as there are two sets of marks that look the same, also there is an anti-backlash device that needs to be preloaded. I'll bolt down the manifolds when I get back from the DMV. Going to licence the Honda Insight, insurance is only $74 a year more for it.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Varn (01-12-2013)
Old 01-12-2013, 11:42 AM   #19 (permalink)
Do more with less
OD - '05 Econoline
90 day: 18.64 mpg (US)
Joetta - '86 Jetta Turbo Oil Burner
90 day: 49.71 mpg (US)
Benzilla - '85 300D
90 day: 28.08 mpg (US)
Tony
Just went to the link mentioned and it looks like they show the exhaust manifold on the same side as the intake cam.
4A-FE Cylinder Head
"A man is not finished when he is defeated. He is finished when he quits."
Richard M. Nixon
"The reward of suffering is experience."
Harry S. Truman
"If you've got a business—you didn't build that. Somebody else made that happen."
Barack H. Obama
Old 01-12-2013, 01:07 PM   #20 (permalink)
arcosine's Avatar
sc1 - '98 sc1
Team Saturn
C - '97 R40
Y2K - '00 Insight
Hi Dave,
The 4A-FE engine is a cross flow head, the exhaust is in front and intake behind.
- Tony
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
