Old 03-07-2009, 07:41 PM   #11 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
what are the power curves of your two engines? might want to keep your current tranny if possible, you might also check out kits for addapting other engines in to S-10 trucks, it's an Issusu truck (right?) so you might want to see if they did make a diesel...
Old 03-07-2009, 08:45 PM   #12 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by my first gmc View Post
Like this?
Eggasctly.
Originally Posted by bennelson
Of course it is NOT going to match the engine mounts or the transmission. Making all that work is going to be the fun part.
Just grab a manual trans from a 65 or earlier (IIRC) Mercedes diesel so that way you only have to fab a crossmember for the trans and then use an adapter/lengthen or shorten the driveaxle. The motor mounts are in the same rough locations IIRC so that shouldn't been too bad. That said, like Ryland mentioned, it'd probably be easier to grab a diesel out of a 85 or earlier S10. Given GMs track record it'd almost certainly be bolt and go.
Old 03-07-2009, 09:45 PM   #13 (permalink)
my first gmc's Avatar
Sierra - '96 Sierra
90 day: 20.89 mpg (US)
White Lightning - '010 Lancer GTS
90 day: 27.18 mpg (US)
Originally Posted by bennelson View Post
Of course it is NOT going to match the engine mounts or the transmission. Making all that work is going to be the fun part. (I also have no idea how to make the speedometer work right!)
Engine mounts should be pretty easy to fab up. And trans cross members are easy as pie to make. Have you looked at after market gauges, that would be way easier than trying to get the stock gauges to work properly.
Old 03-07-2009, 10:56 PM   #14 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Take the clock (the big round face part of the speedometer) and cable from the Merc and graft it into the S10 cluster.
!?Poof?!
Instant speedo
The tires should come out to approximately the same diameter.
OR
Put it all together grafting the Merc trans cable to the S10 clock and get your local speed shop to re-calibrate the speedo to match the speed.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 03-10-2009, 03:08 PM   #15 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
15th post in another epic thread!
I vote for the Merc hubcaps also. And "S-Class".
Old 03-10-2009, 07:12 PM   #16 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I like the project idea. A Benz four cylinder diesel and four speed dropped into a S-10. The engine is legendary for its durability and being straight mechanical, it requires no computer brain surgery.
I myself like the funky panache of the five-cylinder 617.952 (you have to learn Mercedesspeak) engine at an idle, but at 125 HP, it is probably too powerful for a fangs-out MPG project.
There are all sorts of mod kits for S-10s. I’d start with a practical 3”/5” lowering (slam in sport truck parlance) kit. This is low enough to get you a noticeable improvement in MPG but will not high center you on every dead dog on the road.
Air dams and “ground effects” (side skirts) kits galore are available off the shelf.
One thing to consider. The drive shaft will have to be specially made. Benz drive shafts use a DIN flex plate (three big rubber bushings) each end at each end where the GM axle uses a SAE U-Joint. The DIN joint is a bit touchy about alignment where the SAE is usually A-OK if the alignment mismatch does not exceed five degrees.
In any project the fewer “wheels” you have to re-invent, the better the project. The wealth of off-the –shelf stuff available for the S-10 makes it a favorite among project builders.
Don’t forget a tonneau or fastback fairing. Very effective in improving MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 03-10-2009, 09:25 PM   #17 (permalink)
Sierra - '96 Sierra
S-10's sit pretty level, so if you lower the back more than the front, the back will be lower than the front and might cause adverse aero affects underneath. I have a friend who did a 3/3 and it rode really good, and my other friend did the 6/6, riding in that thing was sick.
Old 03-10-2009, 09:40 PM   #18 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Rust repair
Ben - check the .pdf here:
ftp://www.rustrepair.com:24/s10.82.pdf
They have 1/4 and rockers for your truck, and if you go here:
Auto Body Parts, Body Panel, Quarter Panels, Rocker, Door Skins, Floor Pans
They have instructions for both welding and glue-on panels.
Old 03-10-2009, 10:13 PM   #19 (permalink)
Sierra - '96 Sierra
Ben, if you can, get good quality panels. Cheap Chinese ones are out of shape most of the time and are super thin so they dent really easy.
Old 03-10-2009, 10:36 PM   #20 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
After messing around with that Mercedes hub cap, I realized how the crummy plastic rim covers I have would be a great start for some aero hub caps!
The master plan on the entire project includes:
Diesel engine swap (and running on Bio-diesel)
Aero-hubcaps
Aero-Cap (possibly hinged, more than likely to be fiberglass)
Lowering the vehicle? (not sure about that one. I lowered the back 3 inches with blocks a while back, but then I couldn't load up my electric motorcycle anymore, the bed hit the bump stops. Maybe airbags?)
Different differential gears (I don't know too much about this, but I think with the extra diesel torque, I could go to a little higher gear in back.
I have a Mercedes 240D sitting in my driveway right now, to use whatever parts off of it I need. The 4 cylinder diesel is almost the exact same size as the S10s 2.2l engine. Unfortunately, only the automatic transmission was available in the US for the 240D.
Unless I can dig up a 240D MANUAL transmission (and customize the driveshaft) the current plan it to pull the diesel engine and figure out what adapter plate would be needed to mate it to the truck's transmission.
I did do a search for the diesel S10s a while back. They were made for about 2 years, and basically DON'T exist anymore.
That's sort of the the starting point as to why I am doing this project. There ARE NO decent (not HUGE) diesel pickup trucks in this country! The old Mercedes diesel engines have a great track record - so, put the two together!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
A Pickup Truck Project Big Dave EcoModding Central 47 09-12-2011 12:42 PM
Aeromoding my truck ('95 Chevy S10 pickup) bennelson Aerodynamics 42 12-17-2010 07:28 PM
The Classic: my 1969 Chevy CST/10 resto project texanidiot25 The Lounge 5 04-26-2010 02:22 PM
Budget chevy lumina project. ihatejoefitz Introductions 4 04-19-2008 07:41 PM
