Old 04-11-2010, 11:06 AM   #11 (permalink)
I guess I'm living with the rims and tires I have for now and will simply work on fine-tuning the PSI and do other mods. The tires are 195/60R 14 and are 20 mm (0.78" or ~ 3/4" of an inch) wider than stock (195 vs 175) and about 6.6 mm or 1/4" taller. The 185/65R tire size is ~ 1/2" taller than stock. Anyhow....this about wheels....so...
Here is my car and rims:
Old 04-11-2010, 11:36 AM   #12 (permalink)
I guess I'm living with the rims and tires I have for now and will simply work on fine-tuning the PSI and do other mods. The tires are 20 mm (0.78" or ~ 3/4" of an inch) wider than stock (195 vs 175) and about 6.6 mm or 1/4" taller. The 185/65R tire size is ~ 1/2" taller than stock. Anyhow....this about wheels....so...
As you can see, they are 14" x 6.0 alloys and only a Plus zero upgrade. 195/60R 14 is not much wider than either stock width (175/65R and 185/65R) and right in between each in terms of height. It's not like I'm pimping out my ride with larger rims and much wider tires.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Scangauge: Bad pump messed up gauges bryan11 Instrumentation 3 03-20-2010 10:03 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Louvered wheel wells on race cars Tango Charlie Aerodynamics 33 10-24-2008 11:18 PM
