Old 02-06-2012, 12:47 PM   #11 (permalink)
Fat free ranch for life!
Ultra-Orange's Avatar
The Angel - '93 Legacy Sport Sedan, silver anniversary
Actual Size - '93 Metro XFi
90 day: 43.53 mpg (US)
I am beginning to think the lifters are the cause of the noise. Following Big Nasty's advice I put a quart of ATF in the engine and have driven a couple tanks on it as such, The motor is now quieter (still a bit of rattle) and alot more friendly when cold and at low RPMs.
Thank you all for the great input!
Old 03-05-2012, 01:53 PM   #12 (permalink)
Piston slap
Piston skirt slap is a common problem with these. Sounds like a diesel and is loudest when cold and when the engine is under load. I got the same problem. The pistons will eventualy break. The skirts wear out and snap off. Rebuild it (with new pistons) before they do.
The Following User Says Thank You to Mpdonalson For This Useful Post:
Ultra-Orange (03-05-2012)
Old 03-05-2012, 01:57 PM   #13 (permalink)
Not lifters
I too replaced all of my lifters. Wasted my $. Sad thing is the engine was supposed to be freshly rebuilt. The builder reused the old pistons. The edges of the skirts were razor sharp.
Old 03-05-2012, 02:11 PM   #14 (permalink)
Also beware xfi pistons are different than all other metros. They have only one compression ring (zero gap) and tend to be hard to find but are a vital part of an xfi.
Old 03-05-2012, 10:10 PM   #15 (permalink)
Thinking it could be piston slap. Engine has 200k miles on it and it wasn't treated kindly, thank you for all your input!
