Old 01-24-2012, 10:50 PM   #101 (permalink)
EcoDreamer
Those look like they would do the job...but I can't figure out how you would mount them because you would still need the regular hydraulic calipers.
Old 01-25-2012, 02:52 PM   #102 (permalink)
Mount them on the other side of the disk. Or possibly next to the regular caliper (above/below). Regardless of which way you go, you'll have to fab up some brackets for them.
Another thing that has been considered by kit-car people is, if your car has a CV joint right at the differential's output flange, to sandwich a thin rotor between the flange and the joint. Then mount the caliper to the diff.
-soD
Old 01-25-2012, 05:25 PM   #103 (permalink)
EcoDreamer
A thin disk at the differential would work with a Miata rear end but not the Geo. I was wondering if it would be possible to heat the caliper mounting arms on the upright and bend them together. Not sure if this would weaken them or not. Would certainly be tricky to get them bent just right. It might be possible to make a bracket for just one side of the caliper to adapt to the mounting hole, will have to try and figure that out. Since the project is on hold for now, due to my wife's health, maybe Jack or someone will have it all figured out by the time I get back to it.
Old 01-25-2012, 09:15 PM   #104 (permalink)
JackMcCornack's Avatar
I got some salvage yard Suzuki Swift GT rear calipers--they're the right thickness for the Metro front discs and they have hydraulic driving brakes and cable parking brakes. I haven't figured out how to mount them yet, but I'm confident I will.
Oooh, I hope I haven't jinxed it. Maybe I should say, "I'm overconfident I will."
PS--the Swift GT has vented front rotors, which I think are overkill for this car. There won't be a lot of weight transfer on braking and there'll be some rear weight bias at rest, so I think the same brakes all around will be fine.
Modding MAX, a Kubota-powered classic sports car
http://www.kineticvehicles.com
Last edited by JackMcCornack; 01-25-2012 at 09:21 PM.. Reason: added a PS shortly after I hit "Post Quick Reply"
Old 01-25-2012, 10:48 PM   #105 (permalink)
EcoDreamer
I'm rootin' for you Jack. I am overconfident that you will figure it out too. Looking forward to seeing how it is done.
Did you check out my welding instructor in locostUSA?
Old 01-26-2012, 07:43 PM   #106 (permalink)
Jack, do some testing to make certain about where brake lock-up occurs. There are adjustable proportioning valves that you can buy that will limit pressure to the rear brakes, so if the car is too rear-biased you can fiddle with that to some extent.
The time when you are most prone to rear brake lock-up is on a downhill with excellent traction--having good grip under braking will transfer more weight forward than having low grip.
-soD
Old 05-19-2012, 08:34 PM   #107 (permalink)
EcoDreamer
Things are still on hold until I can get settled into my new home in Arkansas. My wife passed away in February and things have been pretty hetic since then.
I am still in PA but had Jack ship my fiberglass parts to my stepdaughter's house in AR. They arrived a couple of weeks ago and I had planned to go down this week but rainy weather made getting a loaded trailer from my shop on the hill above my house too dangerous. Having enough trouble selling the house as it is without a pickup and Uhaul trailer sticking out of it.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Project 60/60 Xfi Metro and Singh grooves metromizer EcoModding Central 25 09-19-2008 08:25 AM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
