Old 11-28-2007, 03:35 PM   #31 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Feeding the aero/rr web tool my car's stats, and varying just the ambient temperature, I get the following:
Temp: ... 15C/59F ... 25C/77F ... mpg change (from lower temp)
45 MPH ... 74.48 mpg ... 76.28 ... 2.36%
50 MPH ... 63.9 mpg ... 65.54 ... 2.57%
55 MPH ... 55.22 mpg ... 56.71 ... 2.63%
Avg difference: 2.52%
Old 10-02-2008, 01:17 PM   #32 (permalink)
thanks for thw work you've done!
I too have been toying with the idea of a trans swap, but it may be too much. I love the look of my new wheels, but they are a bit too tall and def wider. going from the factory 145R12 to 175/65R14 I figure my gearing from a stock 4.1(91 metro) to be a 3.78. At home I have 2 trannies because I want to get another metro and have one for fun(this one now is for fun and econo, so i'm stuck in a cross-hair). I have a 3.52 and a 3.79.
If I'm right, the 3.79 would give me a 3.49, and the 3.52 would give me an overall 3.24....which could be unbearable with such big wide tires on. Oh, what to do......
Just filled up yesterday, so I'll see what my mpg is and go from there. Maybe I'll wear down these tires for the next 2yrs, then go thinner again and to 13" with steelies before I do a swap. putting rear disc on and front vented rotors probably added weigth, along with a neon center console, so maybe this will be the fun car then, since I still have sway bars I want to install.
Old 10-02-2008, 01:36 PM   #33 (permalink)
Without the XFi cam (more low end torque), I'd be reluctant to go with the 3.52 final drive with taller tires on the car. But with it, I'd probably do it. Then you'd have bragging rights for the tallest effective gearing in a Metro that I know of.
That help?
Old 10-02-2008, 10:22 PM   #34 (permalink)
Metro-I thought you remembered-I do have that cam
I can't seem to get my distributor to go past 5* though.....
Tranny would be nice, but do have atleast one big hill home in either 3 directions.....I may get the urge to atleast throw in the 3.79 to start.
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 12:32 PM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Toying with idea of taller Metro 5th gear (to go with the already taller final drive) MetroMPG EcoModding Central 90 12-02-2009 09:03 PM
VX final drive swap: Who to believe? Cleft_Asunder EcoModding Central 28 01-28-2009 09:17 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 5 01-11-2008 11:41 PM
