Old 01-13-2010, 09:40 PM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Bob: that's actually the first difference I've seen mentioned about the ECU.
Old 01-13-2010, 11:56 PM   #12 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
Lobe height is 39.63mm. That's an XFI cam in good condition! The normal cam lobe height is almost 1mm taller.
As a bonus, I got a Daikin clutch with almost no visible wear. It still has writing on the disc.
I'm using the Swift 3.52 gearbox over the 3.79 XFI box.
Old 01-15-2010, 09:46 PM   #13 (permalink)
Custom User Title
I stumbled across this browsing through my 1993 Metro service manual.
Notice the offset ring gap.
I'll get an actual pic when I pull the pistons out.
Old 01-26-2010, 08:44 AM   #14 (permalink)
Custom User Title
XFI piston:
XFI piston ring:
It might be hard to tell from the pic, but the staggered gap is also angled. I haven't checked if the gap is within spec yet. If it is, I might reuse them with new oil rings. Is that a bad idea?
And another craigslist score, engine stand for $10!
Old 01-26-2010, 08:55 AM   #15 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...unlike in art, a patina like that is definitely NOT something you want.
...some soaking in MacKay's Engine Cleaner will remove that gunk, but it'll also make all "wear" clearances/tolerances get bigger.
...lastly, the "top" compression ring might be a problem, because it rides right up against the "wear ring" in the cylinder -- installing a new ring with its new, unworn, 'square' ring edge will be "crunching" up against "the rounded" wear ring in the cylinder...and could result in a broken ring. MORAL: the top ring and cylinder bore cleanup are critical to longivity.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 01-26-2010, 09:33 AM   #16 (permalink)
Nice photos, thanks. Interesting detail on the gap in the ring. I take it the 2-ring pistons don't have the same style ring?
Old 01-27-2010, 07:46 AM   #17 (permalink)
Custom User Title
Everything will be very clean when it goes back together.
I'm going to hone the cylinders, is that good enough? I don't see much wear in the cylinders anyway.
Old 01-27-2010, 08:01 AM   #18 (permalink)
Custom User Title
My replacement rings (NPR brand) have normal flat gaps. I'll dig up some non-XFI pistons and see what the rings look like. But I'm pretty sure they're not like the XFI rings.
Old 01-27-2010, 10:22 AM   #19 (permalink)
Thanks. If you're willing, I'd like to know more of the specs between the two pistons/rings. To determine if a simple "ring delete" is a valid modification to a non-XFi engine.
I realize it would be a lot of work for a tiny gain, even if it could be safely done (safely in terms of the wear/mechanical implications to the motor). Just noodling.
Old 01-28-2010, 08:43 AM   #20 (permalink)
Custom User Title
The XFi piston places its single compression ring in a slightly different location than the top ring on the normal piston. I don't know if that's significant or not. The XFi and standard top rings are the same size, but only the XFi has the special "gapless"design. I don't see why you couldn't give the standard pistons the XFi treatment. Maybe the extra/open ring groove will collect goo and keep the other rings cleaner.
Another view of the special gap. Same ring, just flipped for the second pic.
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MetroMPG (01-28-2010)
converting 98 chevy metro to XFI 00. EcoModding Central 6 02-26-2010 08:04 PM
Metro owner mulling over swap to XFi transmission and 1-ring pistons MetroMPG EcoModding Central 10 02-04-2009 01:56 PM
F/S 1993 Geo Metro XFI $1500 in new parts in NY fly in drive home shanksyamaha For Sale 0 12-26-2008 12:58 PM
Recently purchased 1994 Geo Metro XFi Z33ky Off-Topic Tech 10 11-15-2008 08:12 AM
Project 60/60 Xfi Metro and Singh grooves metromizer EcoModding Central 25 09-19-2008 08:25 AM
