Old 01-13-2010, 05:37 AM   #1 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
Talking Metro XFI Score!
I found a Geo Metro engine on craigslist. I found out it was from a '91 XFI and I went to get it. I got the engine, transmission, axles, radiator, ECU, fuel tank and a bunch of various little parts. All for $100!!! I have yet to verify if it really is an XFI, but I'm happy either way for the price.
It's supposed to be a good running engine, but I haven't heard it run. I was going to rebuild my late '94 engine, but now I'm not sure. I could rebuild the XFI engine or rebuild the non-XFI engine and just stick the XFI cam in it. Anybody know if the XFI piston rings are the same as the normal engine's top rings? Or is it a special design?
Old 01-13-2010, 09:08 AM   #2 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
They just leave one of the rings out for friction purposes I believe. If I were rebuilding an engine, I would find some Total-seal rings (better compression) to put in there, JohnnyMullet would know about the number of rings.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 01-13-2010, 11:18 AM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
No, it's a different, XFi-specific piston. Not just a regular one with one ring left off.
That said, I'm not sure if it's the same ring as the non-XFi. When you find out, please post back though.
And... congrats on finding the $100 parts pile!
Old 01-13-2010, 11:52 AM   #4 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
I would rebuild the non XFi, and then put the XFi cam w/ a +4 cam gear and ECU on it. Should do about as good as the XFi.
Old 01-13-2010, 12:04 PM   #5 (permalink)
What, and give up the massive fuel economy benefit of the 2-ring XFi pistons???
Old 01-13-2010, 12:19 PM   #6 (permalink)
Custom User Title
I just read some reviews on the Total Seal rings and some people have had problems with them, while others love them. I don't think they're worth the risk. And they're not cheap either. $126 from Jegs. I got my NPR rings on eBay for $22.
I probably won't be using the XFI ECU. I'd have to basically convert the whole 1994 Metro to a 1991 and I think I'd lose the ability to use my Suzuki scan tool with the older ECU. What does the XFI ECU do differently anyway?
Old 01-13-2010, 01:06 PM   #7 (permalink)
Custom User Title
Taking a closer look at the engine, I see it's a '92, not '91. Which means I should be able to use the XFI ECU with my scan tool. Now I need to measure that cam. Wish me luck!
Old 01-13-2010, 03:53 PM   #8 (permalink)
The Geo - '93 Metro
Do you mean measure the lift/duration?
Old 01-13-2010, 05:22 PM   #9 (permalink)
Yep, lobe height/lift is shorter on the XFi.
Hope it turns out to be the lucky cam.
Old 01-13-2010, 08:03 PM   #10 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
The ECU runs leaner on the XFI, and the tall gears are a big help, too. You can probably measure the cam right through the oil filler using the depth guage on a caliper, close enough for identification.
converting 98 chevy metro to XFI 00. EcoModding Central 6 02-26-2010 08:04 PM
Metro owner mulling over swap to XFi transmission and 1-ring pistons MetroMPG EcoModding Central 10 02-04-2009 01:56 PM
F/S 1993 Geo Metro XFI $1500 in new parts in NY fly in drive home shanksyamaha For Sale 0 12-26-2008 12:58 PM
Recently purchased 1994 Geo Metro XFi Z33ky Off-Topic Tech 10 11-15-2008 08:12 AM
Project 60/60 Xfi Metro and Singh grooves metromizer EcoModding Central 25 09-19-2008 08:25 AM
